in need of IET Fellow to Support my IET Fellow membership application
Hi All , I recently applied for IET Fellowship with two supporters, one being an IET Fellow and the other my direct manager , unfortunately the fellowship team declined the IET  fellow supporter , stating that they were no professionally connected with me .
i find this unclear , as i had explained my field of work , experience and projects in detail to the supporter before they agreed to endorse me and that itself its the first line of  pass through  and i don't understand what does it means by professionally connected , definitely the supporter has not worked with me before and that would be case for the majority of the IETF application where their IETF supporter has never worked with them .
Has anyone else faced a similar situation and how did you resolve it ? Alternatively , if any IET fellows here would be willing to support my application , i will be truly grateful for your guidance and endorsement , thank you in advance .
  • Artem, they are there as I personally have been involved in assessing FIET applicants from Meta. Some amazing stories too.
  • Gerard, there may be some across 100k SWEs at Meta, but within my org and the closest orgs (hundreds of people with whom I worked), there are none.
    When I asked people around, they mentioned that they'd like to join IET, but there are no referrals in the org :'(
  • Let's say I worked at Meta in the UK for 5 years. It's a reputable, well-known, hard-to-get industry-leading company with an impact on billions of users worldwide. But I don't see any IET fellows around in the company. It looks like a dead end for the whole industry-leading company getting into IET, unless someone(me in this case) gets into the IET circle.
    Hi Artem,
    Yes that makes really good sense. That said, I will say that you don't need to get too worried about that way in being fellowship: membership and CEng is just as good a way of getting into the IET - and is much easier. Once you are a member then by getting even slightly involved in the IET it's pretty easy to find supporters for Fellowship if you decide you want it.
    The only reason I eventually applied for fellowship was because so many of my friends in the IET kept asking me why I hadn't applied yet!
    However, that all said I still agree with you that there needs to be a way that potential fellows can be supported by people other than FIETs - and as Gerard says, as far as I'm aware they can.
    Thanks,
    Andy
  • they mentioned that they'd like to join IET, but there are no referrals in the org
    Hi,
    As my other message, you don't need referrals for membership, just suitable qualifications (and money!)
    Thanks,
    Andy
  • >> Once you are a member then by getting even slightly involved in the IET it's pretty easy to find supporters for Fellowship if you decide you want it.
    I think this will not be easy to use such a supporter. I contacted the IET support to clarify this, and they clearly said that:
    1) "both supporters need to be able to verify all provided information within your Fellow application". This means I can't use any work-related contributions with such supporters who are not from my org inside Meta.
    2) "You should know them at least two years" - this means I have to wait 2 years until I can use such a supporter even for a public activity. E.g I have a YouTube channel, public articles, public media coverage, I created and led mentoring communities with tens of thousands of participants, but I can't use any of that in my application for at least the next 2 years :'(
    I hope there is some logic behind those requirements, but it sounds like an unreasonable limitation for me.
  • You need to be careful re point #1 as it all depends on which criteria you choose. It may be possible to use FIET extrenal to meta if your evidece is extrrnal to meta. for instance if you sre offering evidence of industry forums or standards bodies etc then people external to meta sre valid people to validate and support you. I know people that have never worked with me but i know them from stanards and projects and i would be more than happy to support them. So its not so black and white.
  • 2) "You should know them at least two years" - this means I have to wait 2 years until I can use such a supporter even for a public activity. E.g I have a YouTube channel, public articles, public media coverage, I created and led mentoring communities with tens of thousands of participants, but I can't use any of that in my application for at least the next 2 years :'(
    That's not correct either, provided people of standing have known for two years that you have been doing this then that's fine. If they don't then it's back to the point I made above - the point of Fellowship is to recognise those who have made an impact on the industry. If you can show that you have been recognised by leaders in your industry for the last two years then you're eligible for Fellowship, if you can't you're not. That's really the point.
    Also it's not about what you've published, publishing stuff is easy these days, it's about whether this has had an actual impact. If it has had an impact, then you should be able to find someone who can say it did.
  • To try to bring this to conclusion (because it feels like Gerard and I are repeating ourselves here), I would suggest you resubmit with a second supporter who has known your work for two years who is at a responsible level: for example the CEO, CTO or Technical Director or similar of an engineering company, or the chair of a national or international industry committee, or a senior (internationally recognised) academic in your field - basically the sort of people who would clearly be eligible for Fellowship were they to apply. They do not have to be in Meta, but they will need to explain how they are aware of your work.
    However I would also strongly suggest, if you haven't already, that before you do this you consult a Fellowship Adviser at the IET to review your application. https://pra.theiet.org/search-advisor  They can also offer an opinion on your choice of second supporter.
  • spot on andy!
  • That's not correct either, provided people of standing have known for two years that you have been doing this then that's fine.
    It seems strange to me that the IET support provides completely different information from what you provide here. They clearly said: "You should know them for at least two years". I'm confused about whom I should believe on such qualification questions.
    If you don't mind, if you are on the IET committee, can I refer them to your quotes on this (and other) questions?
