Maximum current for a unit supplied from a 13A socket, taking supply voltages into account.
I am currently developing a heated food merchandising unit to be supplied from a 13A three pin plug.
If the unit is designed around 230V, 13A,  do I have an issue when the supply voltage is at the top of its tolerance (230V + 10% = 257V).
As I have a purely resistive load, the current drawn would be 14.3A
Is this an accepted method or should the unit be designed around 257V 13A?
Your help would be appreciated.
Tony Hoare
    0 Former Community Member in reply to Zoomup
    Voltages and power levels are a bit different for boilers. The Ideal 30kW combi, which means the energy consumption of 1,000 joules for 1 second, so 30kW is defined as 30,000 joules for one second.
