Arran Cameron:
All examination is actually more inclusive. A coursework component is prohibitive for the following categories of people:
1. Home educated children - regardless of which of the 1001 reasons that they are home educated.
2. High academic ability children who want to take GCSEs outside of the school system before Y11.
3. Prisoners.
4. Adults who are self taught or attend distance learning courses who are unable to attend college regularly due to transport issues or work / childcare commitments.
Should these people be denied the opportunity to take GCSEs because it's near impossible for them to have the coursework assessed?
I read on a forum that one reason for the decline in the number of students taking D&T subjects for GCSE (since 2000ish) is because there is a large coursework component.
Lisa Miles:
If I had done GCSE's instead of O levels then I probably would have got higher grades due to the coursework inclusion. Although I did 'pass' most of my exams with C's and B's anyway.
.... Apart from maths.... I was always (and still am) really rubbish at maths. I failed my O level (D grade) and ended up doing a CSE in maths instead and getting a grade 1 which was equivalent to a C grade pass at O level anyway!
I suppose in Maths, my coursework was good because I had time to think through everything but under exam conditions I just got too flustered and couldn't work everything out in time.
You might have picked a bad example because maths is a subject that naturally lends itself to all examination more so than creative or essay based subjects. For example, history is a subject where exams require the ability to (hand)write lengthy paragraphs in a short space of time whereas coursework assignments (which are also lengthy paragraphs) can be completed at leisure and typed on a computer. Coursework is closer to the work of real world historians whereas it can be artificial and unrepresentative for secondary school level maths apart with the possible exception of statistical analysis. In fact I have found pure maths coursework assignments to be of a questionable nature. This probably helps to explain why maths was the first subject to abandon coursework.
Arran Cameron:
...history is a subject where exams require the ability to (hand)write lengthy paragraphs in a short space of time whereas coursework assignments (which are also lengthy paragraphs) can be completed at leisure and typed on a computer.
David Houssein:
The other problem with exams is that all it does it prove that you can perform within a snapshot of time. Coursework allows the time to properly research something, write it up and format it well, and then take some time to consider your conclusions, which is much more representative of the real world.
The truth of the matter is regardless of whether we have 100% examination, 100% coursework, or 50:50, the vast majority of the secondary school curriculum in the main subjects is irrelevant for everyday life in the real world and most employment. It's really an exercise in showing the world whether you can learn rather than learning something useful or relevant.
Coursework has its merits if one wants to become a researcher - or possibly a journalist or a lawyer - but only a tiny fraction of school leavers ever become researchers and the figure isn't much higher for lawyers or journalists. In higher education where research is carried out and findings cannot easily be presented in a few short paragraphs under examination conditions then coursework has its place. In fact I'm a critic of large numbers of exams in engineering degree courses. However, for basic elementary knowledge in the main subjects at secondary school level then I believe that exams are the most effective method of assessment.
Lisa Miles:
I never had the luxury of typing out coursework on a computer, all homework, coursework etc was hand written in exercise books..!Or the luxury of using the Internet for reseach either... In fact my 'research' was mostly done in the reference section of the local library in the evenings and out of the way of my then 18 month old brother...
