Andy Millar:Denis McMahon:Have braking distances improved over time? I am not so sure. However good the driver or the brakes, ultimately it depends on the coefficient of friction between rubber and asphalt. Since this is a fairly innate physical feature, my guess is that it has not improved by much. I should be very interested if anyone has any reliable data on this. It is probably sensible to stick to the long-established figures for braking to stay on the safe side.
Oh gosh yes they've improved. First disc brakes and then ABS were quantum steps in braking improvement. But whether braking distances have improved significantly in, say, the last 30 years I'd agree is perhaps more open to question. They probably are improving incrementally due to improvements in tyres, road surfaces.
Just found this article https://www.diaryofanadi.co.uk/?p=21456 which in turn refers to this one https://www.howardsgroup.co.uk/news/group/stopping-distance-is-the-highway-code-wrong which have a range of strong viewpoints and calculations on this issue.
However, I very strongly suspect that the excellent braking of modern cars gives a false sense of security, and may well have caused drivers to drive faster without full awareness of the observing and thinking time factors.
Cheers,
Andy
Yes, Andy, brakes certainly have improved. Disc brakes avoid the fading effect of drum brakes. ABS prevents wheel lock, i.e. skidding, and avoids reliance on the skill of the driver to apply "cadence braking" or whatever. Tyre improvements seem to be mainly in tread pattern design. This is designed to maximise removal of water in wet conditions, and probably has little effect in dry conditions.
I have visited the web sites you suggested and studied them with interest; I've bookmarked the ADI one for further reference since it is a useful guide to all sorts. Although there are calls for revision of the Highway Code advice on stopping distances, there is unfortunately no real data or theory to back this up. I did say earlier that coefficient of friction was very relevant and was seeking information on how this has improved over the years. Such information has not been forthcoming so far so I did a bit of "digging" myself. The following web sites are relevant and interesting.
www.engineersedge.com/coeffients_of_friction.htm
hpwizard.com/index.html
www.engineeringtoolbox.com/friction-coefficients-d_778.html
The overall consensus seems to be that the coefficient of friction between rubber and asphalt varies between about 0.6 and 0.9. The latter figure applies to non-skid braking in dry conditions; the lower applies to skidding during braking or to wet conditions. Another interesting web page is:
en.wikipedia.org/wiki/Braking_distance
From here I quote:
. . . The braking distance is one of two principal components of the total stopping distance. The other component is the reaction distance, which is the product of the speed and the perception-reaction time of the driver/rider. A perception-reaction time of 1.5 seconds,[2][3][4] and a coefficient of kinetic friction of 0.7 are standard for the purpose of determining a bare baseline for accident reconstruction and judicial notice;[5] most people can stop slightly sooner under ideal conditions. . .
Rob Eagle:
Israeli roads? Why the reference to Israeli roads?
Well, the original question only referred to "our roads", without actually specifying a country. It all depends on where the writer is.
But why does it matter? Would you assume that what other countries do can tell us nothing about what we should do in the UK?
How do different countries tackle speeding on their roads? What could we learn from them?
