Rob Eagle:
I think you’ll find it’s a lot bloody quicker than that! Try the speed of light and you will be closer.
I get the feeling there is a big gap in your knowledge of electricity.
Of course there are gaps in my knowledge, nobody knows it all.
I was told to just make sure that I understand my bit, which I do thank you very much!
Therefore I refer you to the original post:
Demonstrate to the world that that graph is correct at the relevant supply voltage (of 230v) and collect your Nobel Prize for making the biggest contribution to electrical safety since the invention of fuse wire.
Coby:Rob Eagle:
Simple, more current flows, as I said, it’s Ohms law.More current flows faster!
Hang on a minute. If you increase the voltage and the resistance stays the same, less current is going to flow.
What?
I = V/R
For a constant resistance, increasing the voltage increases the current.
Simon Barker:Coby:Rob Eagle:
Hang on a minute. If you increase the voltage and the resistance stays the same, less current is going to flow.What?
I = V/RFor a constant resistance, increasing the voltage increases the current.
Yeah apology's, needed to do a bit of deleting and editing there.
As usual with electricity, the answer was more simple/logical than it first appeared!
