If you had to put either steam, diesel or electric trains into ‘room 101’, which would it be and why? ?
Typical steam locomotives were less than 10% efficient. The relatively low boiler pressures and no condensors were the main limitation. Some experiments were made with higher steam pressures but they were difficult to fit within the loading gauge. The much higher cylinder pressures in a diesel engine allow efficiencies approaching 40%.
I would have to put steam in Room 101 due to low efficiency, high pollution and interesting problems operating in sub zero temperatures. How do you ensure a water supply?
With opinionated tongue in cheek…….
Diesel, regardless. They're just dull, noisy and an eco-disaster-zone.
Keep steam because it's fun, nicely sonorous and low enough quantities to not be a significant eco-threat (we could always heat the water some other way - see Electric below).
Day-to-day use electric because it's quiet, clean and efficient (but quite dull). Internal generation from fuel cell or maybe fission (in 20 years of course) because cables suck aesthetically, reliabilityally and infrastructurally.
