I hope the Climate Activists are proud of the effect their lies are having on the younger generation
If this survey is real the messages these young people are receiving are completely wrong.
We need to reduce our impact on our planet but CO2 is a complete red herring. The current ECS (temperature increase for a doubling of CO2 in the atmosphere) is centred around 3°C (IPCC AR6). The 2°C will destroy civilisation is simply made up.
  • mapj1:
    Ah yes - even simple things like insulating the sloping section of a roof, instead of the flat of the ceiling does not seem to be handled properly
    When people came to do the insulation in 2010, there were three issues: (1) layingrockwool  insulation on the flat floor of the loft, to insulate living space from roof; (2) blowing pellets into wall spaces, where there are double walls; (3) blowing flock into the eaves/sloping roof spaces.
    Odd that not all of these should be standard in British procedures.
  • Interesting how the CO2 rises and temperature drops. So there must be something other than man made CO2 occurring.
    CO2 and Temperature – Watts Up With That?
  • CO2 and Temperature – Watts Up With That?
    Questions correlation.
    “Jamal Munshi compares the correlation between temperature and CO2 to the correlation between CO2 and homicides in England and shows the homicides correlate better (Munshi, 2018). Spurious correlations occur all the time and we need to be wary of them. They are particularly common in time series data, such as climate records. Munshi concludes that there is “insufficient statistical rigor in [climate] research.””
    So it's suggested that homicides in England are due to climate change, no doubt this will be written on the death certificate.
    See. REBUTTAL to Doctor Merritt: ‘Climate Change’ Does Not Affect Human Health, Weather Does – Watts Up With That?
  • davezawadi (David Stone):
    The IPCC ….. is an entirely political organisation, not a principally scientific one.
    Here is the list of all 234 authors of the AR6 WG1 Report
    https://apps.ipcc.ch/report/authors/report.authors.php?q=35&p=
    Among them are 23 working in Britain, at the Met Dept, Uni Reading; NCAS Uni Reading; Dept Geography, KCL; Uni Leeds; Uni Bristol; Uni Exeter; UEA; National Oceanography Centre; Met Office Hadley Centre; Imperial College. All “entirely political”, “not principally scientific”? It should be obvious that you can't get a job at any of those places unless you are a scientist.
    The other 211 also work primarily for scientific research organisations.
    Exactly what politics do you imagine all these people might have in common? As distinct from the science, which they do all have in common.
    You, on the other hand, like to promote the work of a US “think tank” which wrote a report on how Rachel Carson was wrong and DDT is OK, and which has regularly received tobacco and fossil-fuel industry money. Not hard to imagine what politics it may promote, in particular since it was documented by Oreskes and Conway.
  • Peter Bernard Ladkin:
    Roger Bryant:  The German Greens have done well so far, forcing the closure of viable nuclear plants so the electricity shortfall is produced by burning lignite or importing fossil fuel electricity from Poland.
    Not really an accurate summary of the situation.
    It was the centre-right CDU that exited nuclear, namely Angela Merkel.
    The reason lignite is being burnt is that the miner and energy producer RWE (which has two large open-cast mines at Hambach and Garzweiler SW of Cologne which are continually the subject of demonstrations), has a government contract to do so which runs a while yet and cannot be forced to stop early (people and politicians have tried).
    By the end of 2020, almost half of the electricity in Germany came from sustainables (46%). Current goal is 65% by 2030. We might well get there earlier.
    A little distorted, the Merkel government implemented the legislation put in place by the previous green coalition.
    The Green movement was certainly not in favour of nuclear power then (maybe they are starting to change?). There were protests by the Lingen plant when I used to go by in the mid 80s.
  • When people came to do the insulation in 2010, there were three issues: (1) layingrockwool  insulation on the flat floor of the loft, to insulate living space from roof; (2) blowing pellets into wall spaces, where there are double walls; (3) blowing flock into the eaves/sloping roof spaces.
    Well if you do that last one here you will probably have condensation in the loft and then wet rot of the timbers.  If you insulate the sloping section (rafters) then a bit of experiment will show you must ensure free airflow between the back of the roof tiles and the outer side of the insulation - so in my case I cut polyurethane foam sheets to be a jam fit, but left ~ 40-50mm between that and the back of the tiles so there is an open void from from eaves to ridge.  the loft is then warm and dry. There is then no real need for the ceiling rockwool. Cavity wall insulation is worth it though.
    It is not helped by the fact that defined thermal standards and mandatory insulation first entered the UK building regs in 1984, and then it took quite a while to become standard practice for local builders. (so my parents extension, 1983, was still done in solid walls, to match the rest of the house. At the time the building control inspection chaps were quite happy with that. They would not be nowadays…)
  • mapj1:
    [PBL]……. (3) blowing flock into the eaves/sloping roof spaces.
    Certainly a worry, but it hasn't happened with my building AFAIK. On one half of the building, we put in four new sloping windows (Velux), so had to cut out large sections of the eaves space. All dry; no issue with timbers. Replaced, though with rock wool because that is easy when you have the space open.
    That is now part of standard (re-)roofing procedures. From inside to out: board, waterproof lining, joists, tiles. (And on the inside of the board comes your insulation and more board). But you can't retrofit onto an old roof such as mine. I'd need a new roof and that gets into real €€€€€.
    That's right.
