How 'Green' are solar panels?
I wonder if we'll eventually see the same problem with a growing number of expired electric car batteries too?
Growing number of Solar panels going to landfill due to cost of 'recycling'.
Millions of solar panels in California risk being dumped on landfill sites as they reach the end of their life cycles.
Over the past two decades, more than 1.3 million homeowners and builders took advantage of state incentives to install the panels on their rooftops.
However, they have a lifespan of 25-30 years and defunct ones are starting to pile up in dumps, raising fears they will contaminate groundwater with toxic metals such as lead, selenium and cadmium.
Sam Vanderhoof, a solar industry expert and chief executive of Recycle PV Solar, told the Los Angeles Times it estimated only one in ten panels were recycled because the process is expensive and time-consuming.
It costs about $20 to $30 to recycle a panel compared with $1 to $2 to send it to a landfill, according to figures from the National Renewable Energy Laboratory. “The industry is supposed to be green,” Vanderhoof said. “But in reality, it’s all about the money.”
California, with abundant all-year sunshine, was a pioneer in the adoption of solar power. In 2006 it introduced the California Solar Initiative which granted $3.3 billion in subsidies for installing panels on rooftops.
While the scheme was considered a success, officials are now grappling with how to safely dispose of the panels.
Serasu Duran, assistant professor at the University of Calgary’s Haskayne School of Business in Canada, warned in an academic paper last year that the industry was “woefully unprepared for the deluge of waste that is likely to come”.
The issue is not limited to California — a solar panel was installed every 60 seconds last year in the US, according to the Solar Energy Industries Association.
Duran told the LA Times: “While all the focus has been on building this renewable capacity, not much consideration has been put on the end of life of these technologies.”
  • And isn't that a failing of regulatory bodies? Consider the Walleys Quarry constantly on the UK news for being the most complained about landfill site in the UK, if the prices to dump there were much higher, people would be spending more time and effort in separating waste and recycling more.
  • You are aware solar panels work in varying conditions?
    According to the national grid "The current peak solar electricity generation record seen by our Electricity National Control Centre in the UK is 9680MW on 20 April 2020 – enough to boil five million kettles!"
    I did find this though which seemed interesting:
    "National Grid ESO is preparing Britain’s electricity system to be able to run on purely zero-carbon electricity by 2025 – ready to accommodate whatever quantity of renewable electricity, including solar power, is being generated.
    In order to bring ever increasing amounts of renewable energy onto the grid, and keep costs down for customers, they’re working to overcome two intertwined challenges: ensuring that demand for power is balanced by electricity generated and updating the foundations of the electricity system. Electricity has historically relied on fossil fuels, so they’re designing new approaches and incorporating new technologies.
    In a recent successful test, as part of the Power Potential project, the inverters at a solar plant were upgraded so that, on top of providing power during the sunshine of the day, the plant could also provide a use at night time, smoothing fluctuations in voltage and keep the grid stable.
    Solar power also plays a role in providing frequency response, one of the balancing tools that the ESO uses to keep the electricity system in balance.
    A recent trial saw a contract made up entirely of domestic users, allowing them to get paid to export their excess energy to the grid and help to balance supply and demand with cleaner, decentralised power at the same time."
    Link to that is here: Power Potential | National Grid ESO
  • Suppose it's also worth pointing out, there's an option not being considered here.
    reuse.
    Refurbish the panel and reuse it elsewhere, or use an aging panel in an area that doesn't need the full capacity that the panel had when new.
    There are large parts of each panel which can be recycled though - Solar Panel Recycling | US EPA
  • Thank you for sharing.
    I think its pros at the moment outweigh the cons.
    In the energy transition, solar becoming cheap, and its installation boosted by governments has definitely helped.
    However, the heavy metals used in panel manufacturing are unrecyclable and an impending fiasco that would add to our pollution problems.
    A way to combat this would be to regulate technological innovations and companies to invest heavily in closing the manufacturing loop with sustainable solutions.
  • The thing that is problematic with the lack of spinning reserve, means that the traditional canary in the coal mine of an overload, which is the frequency falling, may not occur as the timing of inverters are derived from the electronics.
    It is possible to emulate this better with some effort, and is being, also the inverters can be switched out of phase with the mains to not invert as such but to load the mains at one part of the 50Hz cycle to fill the internal resevoir capacitor and then to push that charge out at another point in the cycle- in effect  providing a first order phase change power-factor correction that is programmable from cycle to cycle, and on 3 phase systems with further tweaking to load one phase to prop up another.
    As far as I know this can be done quite reliably, and is being rolled out with newer kit at large sites but is not yet common.
    The other more traditional thing that achieves a similar end and can be done of course is to have a large spinning motor/flywheel that motors or generates to smooth things over. Slightly counter intuitively, this is sometimes called a a "synchronous condenser" at least not intuitive to me, for whom the word condenser implies capacitance.
  • Slightly counter intuitively, this is sometimes called a a "synchronous condenser" at least not intuitive to me, for whom the word condenser implies capacitance.
    I can see the reasoning, it is storing energy in a similar manner to a capacitor in a dc circuit. I've always thought an "ac capacitor" would be useful, e.g. (to take trivial case) put across a lamp so that it dims gently on power off, in the same way that a dc lamp with a capacitor across it would. Which from your description (I hadn't come across these before) is what this does.
    Apologies, a bit off a quite important topic!
  • I think the vocabulary is an age thing - condensors and valves are terms from an era of electronics that is passing or maybe past- To be fair it was passing when I was a kid (1970s), but I started quite young and learnt a lot from my father and also his text books, which in some cases were pre-war, and in other cases when he was training in the 1950s. I suspect no-one measures the  electrical capacity of condensors in jars any more, (they are about 1nF) but the 1930s Admiralty handbook of Wireless Telegraphy certainly did.
    Agree its a side track - but the threads support branching. I do not like it, but as it is there, to use it.
