Lane Keeping Assist
We have just replaced our 15 year old VW Touran diesel with a T-Cross 1.0 TSi. This is, as all new cars, fitted with lane keeping assist. I was wondering what would happen if it got confused? Could I, or my wife, fight it and win. Looking at the Bosch variant it either uses the electric power steering, if fitted, or brakes individual wheels using the ESP.
https://www.bosch-mobility.com/en/solutions/assistance-systems/lane-keeping-assist/
“Lane keeping assist uses a video camera to detect the lane markings ahead of the vehicle and to monitor the vehicle's position in its lane. If the vehicle’s distance to the lane markings falls below a defined minimum, the system steps in. In vehicles with electric power steering, it gently, but noticeably countersteers in order to keep the vehicle in the lane. In vehicles without electric power steering, it achieves the same effect by utilizing the electronic stability program (ESP®) to brake individual wheels.
Drivers can override the function at all times, so they retain control of the vehicle. If they activate the turn signal in order to intentionally change lanes or turn, the system does not intervene.”
I am fairly happy with these various assist systems so long as the appropriate risk assessment and performance level calculations have been carried out, so not designed like the Boing anti stall system.
Some while ago I started a thread on EVs apparently becoming immobilised due to battery or other failures.
https://engx.theiet.org/f/discussions/28694/evs-immobilised-by-flat-batteries-or-breakdowns
The new car has a DSG transmission and the selector lever is locked in Park when the ignition is switched off. It requires 12V to be available to release it, so flat battery and the car is immobilized. Reading deeply in the handbook it can be released with a screwdriver (supplied with the car but buried under the spare wheel) by opening a flap in front of the (conventional) hand brake lever. Who, other than an Aspergers spectrum engineer, would actually look that up?
  • Who were these people who could only see a car if it was illuminated?
    I think it's like having orange flashing beacons on machinery at construction sites.  Anyone can see a big yellow bulldozer, but the beacon tells you instantly that its a bulldozer that's liable to move at any moment, and not just part of the scenery.
    In dense urban landscapes, it's all too easy to lose a slow-moving car in amongst a load of parked ones.  To get out of the estate where I live, I have to go through two T junctions before I get to the main road.  I now force myself to stop at each of them and look both ways twice before proceeding.  There have been too many times where I have looked once and started to pull out, only to have a car pass right across right in front of me.
    Motorcyclists have used their headlights during the day for many years too.
  • The problem of course is once you have mis-learnt you need only look for things with lights - unlit cycles or pedestrians or animals are then at a huge disadvantage.
    Equally if one drives in India and some other parts of the world where totally unlit cars and lorries even at dusk or night time are common, it rapidly becomes  truly scary for a western European driver brought  up with 'see and be seen' as the mantra.
    Would running lights make this road safer to navigate ?
    Photo taken from here an article that suggests that the Indian roads are no safer than when I was last there for work a good few years ago.
  • DRLs are a good idea, as Simon says motorcycles have had to have their headlights on permanently for years. But my issue is that it's just the front lights and many drivers rely on just having those on in situations where they really should be fully illuminated i.e. in the fog, at dusk/night time or during a heavy rainstorm.
    If the rear lights were also illuminated in some way or if the dashboard lights were not illuminated unless your full lights were on (if you can't see your dashboard then it's dark enough to have your full lights on anyway) then that would be excellent! Slight smile
  • I've only recently got rid of my old 14 year-old Fiat.  That was too old to have DRLs.  But it did have the very sensible feature that if you turned the ignition off with the lights on, it would turn the lights off for you.  Then next time you turned on the ignition, it would turn the lights back on.
    So for many years, I left the side lights (and hence the tail lights) on all the time.
  • These various new systems seem to cause wide spread problems/confussion:
    Two in five drivers switch off vital vehicle safety features (fleetnews.co.uk)
    I've had to turn off the parking sensors when they are covered in snow and bleeping at low speeds.
  • Good point!  i wonder how that risk assessment proceeded.  Volvo have had all DRL for ages but when mandated it only applied o the front lights.  Odd.
  • Having watched several vehicle reviews on YouTube recently, it sounds like some of these safety features can be very badly implemented on some cars.  Whether it's the lane keep assist that beeps frantically and then tries to pull the steering out of your hands, or the emergency braking system that operates without warning when it's not needed.
    If that's the case, then I'm not surprised if people turn them off.
    So far, the lane assist on my new car only seems to create a gentle rumble - less than I get if I hit the rumble strip on a motorway.  If that's all it's going to do, then I'm happy to leave it on.
  • Simon i think you are right here and it's typical MSM repeating press releases without engaging their brain.  How about disabling a passenger airbag because there is a child seat in the front - yep that would count as disabling a safety feature. Switching off auto-wipe probably does too even though you only do so because it is totally incapable of working properly (unless on a VW see above).
    I quite like the gentle rumble effect, so that is a good driver aid.  But in a free world I surely retain the right to turn it off without the nanny state tut-tut-ing.  Rather like the MoT test that has mission creep and everything now is safety.  My old car failed because the fog light tell tale light had stopped working.  The fog lights were fine but this "safety feature" meant it failed - it didn't need a light but because  it had one that didn't work it was a "fail".  Give me strength.
  • Last year my car failed the MOT as the screen wash jets were not working..... Given that it was minus 10 that day and the screen wash tank was frozen solid (as well as many other drivers screen wash tanks had too) then I'm not surprised Joy
    Gave it some time to thaw out again then lo and behold it passed.... Wink
  • My old car failed because the fog light tell tale light had stopped working.  The fog lights were fine but this "safety feature" meant it failed - it didn't need a light but because  it had one that didn't work it was a "fail".
    Sounds right to me.  So far as I know, it's always been a requirement since fog lights became a requirement.  I'm sure all of us have found ourselves stuck behind a car with its fog lights on, despite there being no fog for days.
    Now imagine how often it would happen if cars didn't have a warning light on the dashboard.
