What electricity really is
I purely by chance read something on quora digest that electricity isn't the flow of electrons but photons that are ejected from free electrons then re absorbed by another free electron this process makes them vibrate  and move forward a fraction of an inch. Now I know there was a discussion  about this on here a while back so what was the final conclussion. I know its a tough subject ide like to get my head round it of course its made harder because I can't understand the maths.
  • Quantum electro dynamics I think is just physicists way of explain  imaginary VARs in 2 directions only.
  • So what ? yes of course it does - its not a problem for physicists, more for folk who do not understand what physics is or how to use it  to describe reality. In general the change in mass of something when it acquires terrestrial thermo-chemical  sort of energies is negligible,  The change in mass of my car when parked in the drive compared to the higher mass when pelting down the M3 or similar is utterly dwarfed the change in mass due to the thermal change in its volume altering the amount of air inside, the steady addition or subtraction of odd dust particles, dead flies on the grill, mud on the tyres or whatever.
    Consider a car with a rest mass of 1 tonne (1000kilos) , Now let us move it at 30m/sec (3600 sec per hour) 96km per hour, nearer to 60 mph than 70, honestly officer.
    Energy is 1/2.m*v^2 = 500,000*30*30 = 450MJ
    Mass change is E/c^2 = 0.000000005 kg = 0.005 milii-grams >  about 1% of the weight of ink in a single printed full stop.
    It only starts to noticeably increase the mass  (making it harder to accelerate) when the speed of the car gets to about 1% of 'c' which would really be going some, even for Mrs MAPJ1 driving.
  • Good thinking Mike, have you ever tried to work out the difference in weight of a 12 volt battery  flat to full charge and its affect on specific gravity ??
  • Well there are several changes in a car battery between flat (2 lead plates and some acid) and charged. Not least the formation of  lead oxide on the positive plate, changes in electrolyte density and so on.  There is of course an energy related  change in mass in terms of how that battery accelerates due to a given force, or indeed if the battery were in outer space and attracting smaller items to orbit around it, but again like the car, practically this is utterly dwarfed by the (in)accuracy to which you can measure the weight of the thing in the first place and then correctly discount all the other effects.
    The only time I have ever really had to consider relativity for real was for part of some medical kit that was designed for accelerating protons. In that the drift tubes between the RF resonator cavities had to allow for the 'speed limit' and did not get shorter at the high energy end of the machine quite as fast (as the protons di not get quite as fast) as normal Newtonian mechanics might have predicted. Even then just using special (Lorenz contraction) relativity was quite enough precision.
    Most of the time, all the relativity and QED  stuff is a diddy correction on traditional mechanics and EM. Normal quantum mechanics however you rely upon  every time you operate a transistor - and there are millions of those in many of the 'chips' in the device you use to read this forum. (the non mathematical holes and electrons model gets you a long way with qualitative arm waving explanations, but to actually design new semiconductor devices rather than just to use ones made by others, and to accurately understand & predict behaviour of band gaps at junctions etc, sadly, needs the full maths, -which is where I usually find myself deferring to a colleague ..)
