UK Smart motorway, at least 79 people killed.
This is though provoking stuff. How has it been allowed to continue?
I had a near miss on the M6. Driving along in Lane 1 (old hard shoulder) at 60 towing a caravan. The car some distance in front of me pulls into emergency area. A couple of seconds later they pull out and in again. Another couple of seconds they pull out again as if to drive off, but they stop in the No. 1 lane and start reversing back into the emergency area. It is now too late for me to stop without hitting them, fortunately the number 2 lane was empty so I swerved into it and went past wihtout time to even blow my horn. There was a car parked in the middle of the emergency area which appears to have caused some confusion o the driver of the car I nearly hit.
I have since noticed how short the emergency areas are and wonder what happens if a long vehicle, even a car towing a long caravan, is parked in one where the recovery vehicle parks? As the telephone is located in the middle of the area it is natural to stop by it leaving two very short areas either side.
I have noticed that on the M25 a red X over a lane is an excuse for everyone to ignore it to get to the head of the queue.
It doesn't seem that long ago we were worrying about the safety of hard shoulders - too many cases slightly tired HGV drivers seeing a vehicle ahead of them in the lane to the left subconsciously thinking they must be in lane 2 and so moving left ... and crunch. So the advise if you did stop on the hard shoulder was to get out, climb any barrier and onto the grass verge a.s.a.p..
One way to ease congestion would be to prosecute anyone hogging the middle lane when the inside lane is clear and those who overtake whilst travelling at 0.5mph faster than the vehicle they're overtaking. I don't think the death penalty is too draconian in either case!
Well, the problem at present is people thinking their speedo is correct . Says 70 but you are only doing 63 in the fast lane.
I normally flash the misguided driver who usually indicates left and moves over. As a last resort I may overtake him on the middle or even slow lane as he obviously is unaware that there is any other traffic on the motorway apart from his selfish self.
Yes, all speedos have tolerances and given that its not legal to sell a car that under-reads speed, all manufacturers set up the speedos to over-read. The % overread depends what speed you are doing and the manufacturer. Depending on how they measure speed, it can be impacted by the pressure of your tyres, wear and tear on various engine parts or sensor lag.
However, if you driver an EV, its more efficient to go at 50-55 mph otherwise you will drain the batteries faster. Unless you have one of the rare EVs with a gearbox that supports efficient motorway cruising.
I don't think I could put up with driving that slow. My Renault Zoe will still deliver decent economy up to 60-65 MPH. If I'm heading home, and the "guessometer" on the dashboard reads more than the miles remaining on the satnav, then I'll stick my foot down and do 70.
When I drive past one of those speed signs that helpfully tell you how fast you’re driving and flash up a smiley or frowny face in my Audi I’m usually 2mph out (speedo says it’s 30 but sign flashes 28. In my VW it’s about 4mph out so flashes up 26 when the speedo says 30!
I used to work for the company that made the speedo in my car, so I know most of the offsets But generally I use the GPS to trim my speed on a motorway. GPS speed can still have errors.
Smart motorways are really designed for when we have V2X on most cars. That way your car can tell the system its broken down and alert other cars in the vicinity. Although, like any new technology, it will take time for that to be adopted by the majority of vehicles. Most of us don't change cars every couple of years.
and that too will fail spectacularly when network connectivity is lost - its all about building intentionally brittle systems - and if you are not careful you are also designing in attack vectors for malcontents to use as well. Look at the effect of GPS and cellphone jammers for example, and their use already in more organized robberies...
Agreed - especially if when they look at the Use Cases for the system they look at the "Sunny Day" scenarios only and forget to look at all the ways the system can fail.
But if you look at all the ways the system can break, can be misused, there are plenty of methodologies that allow the design of a more robust and resilient solution. The real question is, putting in secondary systems costs extra money, will anyone want to pay?
I don't see V2X rolling out other then little test schemes anytime soon (and yes, I know about the ring road near Birmingham) - that will need a massive infrastructure roll out for roadside transponders plus it will most likely take at least a decade for the majority of cars on the road to be fitted with the appropriate onboard equipment.
