What is the ratio of the number of public Gasoline/Petoil pumps to passenger cars?
Example:- 1 public gas pump for every 1 gas powered passenger car.
The uptake of Electric cars in the US is being limited by the small number of public charging points.
It is effectively the same situation as during the introduction of gasoline powered cars in the early 20th century.
But at that time many drivers carried can(s) of  gasoline with them, when they traveled long distances.
Those of us who owned a VW car from the 1960's, (which did not have a gas gauge), will remember having to use the "built in" reserve gas system, operated by a manual foot switch, when running out.
  • However if I was going to have an EV charging point added to my residence it would nave to placed outside. at a reasonable distance from the house
    Shouldn't be an issue - even if there's no suitable wall to fix the charge point to, most domestic ones can be post mounted. An armoured cable can be run along a wall or buried. I guess you have the typical US 2ø 100A@120V supply - so comparable to a UK 230V single phase 100A supply - so unless you have a high existing demand there should be the capacity there.
  • Hello Simon:
    First of all I wouldn't have a Diesel car as it is nearly impossible to get diesel fuel. I guess the closest public place is about 10 miles away.
    I wouldn't buy/have a Korean car which are prone to gas leaks.
    Peter Brooks
    Palm Bay
  • Hello Andy:
    You are correct the cable is usually buried.
    Some families have big RV vehicles parked outside their house which require an external power line connection.
    Peter Brooks
    Palm Bay
  • That's a real positive step!
    Unless one is of the opinion that BEV is not the way forward.
    To change people's minds, advances are necessary in a number of technology (and standards) areas.
    We also have guidance from insurance companies that severely restrict the acceptable locations for charging of EVs, and there are also numerous challenges for on-street parking (which a sizeable proportion of 'parking at home' spaces occupy).
  • I will give you the perfect answer to this whole transportation problem, but you will not like it !
    Make it illegal to own/lease a car (electric or gas powered).
    Only self driving taxi's (cabs) would be allowed for personal transport. You would call for service on your app, and pay for the drive using another app.
    Peter Brooks
    Palm Bay
