The switch from a fuel-intensive to a material-intensive system.
A very succinct description of the problems facing us from E+T.
https://eandt.theiet.org/2025/05/13/electric-building-materials-short-supply
“Solar photovoltaic (PV) arrays and wind farms do not require fuel to operate, but they generally require more materials – including harder-to-find critical minerals and rare earths – to construct than polluting power stations. According to the IEA, an onshore wind plant requires nine times more mineral resources than a gas-fired plant of the same capacity, while a typical electric car requires six times the mineral inputs of a conventional car.”
  • The ‘normal’ metals, iron, copper aluminium, lead etc can be fairly easily recycled/reused and structures already exist for that. Concrete can be broken down to aggregate to be used for further concrete but this still requires new cement. Plastics/composites are, as you say, currently more of a problem.
    All these recycling/reuse operations require energy and that may be where the problem is. Electric arc furnaces are useful for recycling but require a very reliable electricity supply, once they cool down (4hrs?) they are effectively destroyed.
    If combustion heat is required (cement for example) hydrogen generated electrolytically from wind/solar is the proposed solution. This is currently quite inefficient and I wonder if it will close the loop? Looking at a 20 year life span will wind and solar generate enough energy to replace themselves and their infrastructure (which is always left out of the 2 year energy payback figure) or are we trying to make a perpetual motion machine.
  • Roger,
    About the only place in UK with surplus renewable wind is Shetland as no one is building houses/infrastructure there at present.
    We need to stop building everywhere to slow climate change which can be achieved if we stop the need for building new housing because of population growth.
    Bless your 2 kids with a house to inherit or curse them with poverty if you have 4 or more children
  • Isn't that 'Hoarding', as a 'non-material' ;-)
  • Gold used to be used a lot in manufacturing products such as microcircuits.
    Peter Brooks
  • Gold still is used 'a lot' in many parts of electronics and electrical systems but they are careful to use only the minimum needed because of it's 'false' commodity use making it too expensive ;-)
  • you don't need very much gold at 0.7um thickness to do large areas of a PCB - its quite a cheap option. Chips tend to be aluminium or for the expensive ones, copper metalization these days. The dissimilar metal "purple plague" bond wire problem has been solved with barrier layers.
    mike
  • For your information, there are still US locations (examples Nevada, California and Alaska) where one can still do free "panning for gold", , in known gold producing rivers.
    Peter Brooks
