Is Headlight Glare Making Night Driving Harder?
As the clocks went back at the weekend and we're now driving home in the dark, I've noticed that driving at night feels a lot harder lately, and I’m not alone. Many people I speak to all say they find driving at night harder as each year goes past and it's not just because we're getting older! Many of my younger colleagues are feeling the same!
A recent article on the BBC News highlights how modern LED headlights, while great for personal visibility, are causing serious glare issues for many drivers.
Some key points in the article stood out to me:  LED lights are much brighter and more focused, but not always well-aligned. Glare recovery takes longer as we age and the RAC says that a recent survey suggested that 75% of drivers find night driving harder now.
I have to admit that there have been times when I've almost had to bring my car to a stop as the light of the car ahead have been so bright that I've been blinded and simply can't see the road in front of me! It's getting to the point where I really don't like having to go out in the car at night and of course as we're in the 'dark' seasons, driving in darkness is pretty much unavoidable. Pensive
So how can engineers help here? Better design? Smarter regulations? More adaptive tech?
Would love to hear your thoughts!
  • My newer car has LED headlamps.  The beam they project has a very sharp horizontal cut-off. Above that line, they prodice almost no light.  Below that line is brightly illuminated.
    On a flat and level road, this works well.  The lights won't dazzle oncoming drivers.
    But British roads are anything but flat and level. To oncoming drivers, it must look as though I am flashing my main beam headlamps at them.  I coult increase the dip using the control on the dashboard.  But then I wouldn't be able to see where I was going when driving on an unlit road at night.
  • But where does the problem lie Andy?
    Probably equally across the board - not least the buying public that often choose something "designer looking" over base practicalities, and of course the car manufacturers are in a competitive market so what sells goes. Ideally education would mean people only bought sensible things, but back in the real world I guess legislation/regulation will have to be the back stop. Not ideal as they can really only address and issue after it becomes a problem, but such if life.
    Orange and red are very close on the colour spectrum meaning that it can be really hard to distinguish between the two especially when the brake lights are also applied with a tiny little orange flashing light in the centre!
    Ditto from front indicators against bright white headlights - again often an issue for pedestrians/cyclists trying to figure out which way vehicles intend to go at junctions.
  • 2nd though - how about an annual "wooden spoon" competition for the car manufacturer with the stupidest design feature ... might encourage manufacturers to take a 2nd look at things?
  • OMG Andy I LOVE that idea! Joy
    We should do that ourselves through a poll on EngX! My vote would definitely go to the manufacturer with the indicator in the middle of the rear lights!
    I'm going to be on the look out for them now as I really want to know which manufacturer it is....
  • I'm not a lighting engineer, but I suspect the problem is the 'luminous emittance', the amount of light emitted per unit area, for LED head lights results in a much more concentrated light source, which when you look at that incredibly concentrated source of light then results in momentary blinding.
    Typical higher powered LEDs, have a flat construction with light emitted from a small area, on one side only, directly forward and not dispersed, so all of that light is coming from a small area, so is incredibly bright and intense.
    Compared to a traditional head light, where the light from the bulb is emitted in all directions, so spread over a much bigger surface area with the reflector then reflecting and spreading that light forward through a much larger glass or plastic lense, the surface area of the reflector is many times greater than the surface of the LED, so the light is less concentrated and intense than the LED, so less of a blinding effect.
    It's like if you look at a clear filament light bulb, the intense light from the filament is uncomfortable and somewhat blinding, a pearl light bulb with a coating on the bulb spreads the light more evenly across the surface of the bulb so it's less blinding and uncomfortable, and if you put that bulb in an opal glass lamp shade, which spreads the light over something the size of a football, it's not uncomfortable or blinding at all.
    It's likely the design of the head-lamp, the LED needs fitting with a diffuser to spread the light more evenly and reduce the peak intensity.
  • Long ago France required selective yellow headlamps as they were supposed to reduce the glare compared to normal white bulbs by removing the blue component.
    https://en.wikipedia.org/wiki/Selective_yellow
    To me the newer headlamps seem a very blue white rather than the more yellow conventional tungsten filament lamps. Maybe appropriate design of the LED wavelength spectrum or filtering would bring a reduction in glare.
    I do agree that the very sharply defined beam of the new designs are good on a good road but can be very distracting on rough roads. Maybe the soft beam edges reduced this problem with conventional headlamps.
  • My nomination for the wooden spoon award goes to the worrying trend of SUVs and CrossOvers that have auto boot/trunk/Powered tailgates closing by the push of a button or remote or sensor that incorporates the special feature of being able to sever your finger off if caught between the boot door and the main chassis of the frame.  Below is a partial list of cars affected
    Tesla Cyber Truck
    BMW X7
    I am sure if people trawl the internet they will find other makes and models.
  • I remember having to paint our UK car headlight lense with the yellow tint for the drive to Italy.  As I recall France and Switzerland had the requirement for when were drove Mont-Blanc tunnels and Great St Bernard Pass.  My understanding was that this was on the premise of Fog or possible fog.  With the yellow working better than white in the same sense as dipped lights as apposed to Full beam in Fog.  I also recall the UK car needed a kind of black triangular sticker placed on the outside light lense to deflect/cover a certain portion as to not blind the oncoming traffic on the continent
  • I do agree that the very sharply defined beam of the new designs are good on a good road but can be very distracting on rough roads. Maybe the soft beam edges reduced this problem with conventional headlamps.
    It's not just the intensity of the beam as a whole, I think it is highly likely that within that beam there is part of it which is coming directly from the front-facing surface of the LED which has massively higher intensity, which then causes the momentary blindness.
    I had a quick look at the LED head-lights on my car (original factory installed I should add!), looking through the lense to see the LED light source, you can actually see the front face of the LED, the familiar yellow coloured phosphor applied to the LED chips, so looking into the beam you would see not only the general beam ss a whole including light redirected forward from the reflector, but also a central, blindingly bright, peak intensity light, coming directly from the LED chip(s) which would inevitably cause some degree of blind-spots or momentary blindness.
  • I drive a lot in France and there are still quite a few cars that have the yellow tinted headlights!
    We also have to use beam benders on our headlights as it's a right hand drive meaning the lights are configured for driving on the left. The beam benders diffuse the 'focal point' in the headlight housing that would direct the main focus of the light to the left hand side and kind of deflect it over to the right. We very rarely get flashed by an oncoming car so they must be working!
