Electric Plugin Hybrid Cars Environment Friendly City Switch
A government grant should be given to drivers of vehicles who switch off their ICE and run on battery only power inside cities.
Vehicles without this switch including vans should not receive a grant,
To discuss is how to automatically switch the ICE off as the vehicle crosses the line into the zero pollution zone.
At the moment there are cameras at these access points which could signal switch off and switch on when departing.
Hybrid electric car manufacturers could surely fit cars/vans with the necessary auto switch.
  • Interesting.  I do not own an electric car only a bike which runs at 36 volts DC so series connect 4 panels at 12 volts is fine to charge it.
    Electric cars have a motor which I assume is 360 volt which is 230 volts time root 2 . So 400 volt DC is a good match.  How many PV panels do we need?
  • How many PV panels do we need?
    I think the more usual arrangement is to invert the PV output to 230V a.c. and then make it available to a conventional EV charge point (or any other loads or export any excess to the grid). You can then choose the number of panels to give the power you require (again a moving target, as sun intensity isn't exactly constant).
  • The bit I'm wondering about is that ideally we'd want to be charging from solar during the day and from our cheap rate midnight to 5am. With a potential to over-ride if needed. Anyone happen to know if there are off-the-shelf solutions with arrangements of power routing and timers to manage that?
    With the PHEV we just charge overnight from the granny lead through a time switch (yes, I did make sure it was sufficiently rated, in fact over-rated, to switch that load!), but when I go fully electric I'll invest in something meatier.
    My Simpson & Partners charger is supposed to be able to do that.  It has a current clamp on the incoming AC supply, so it can work out if I am exporting or importing power.  It can then ask the car to charge at a rate that makes optimal use of the solar.
    I have never tried using that.  My old solar system will only deliver 3.4kW at the best of times, and at that power, the sun will have gone down long before the car is charged.
    My only use for the current clamp is to stop the charger overloading my 60A supply.
  • (lost previous rely, Forum playing up, try again..)
    There are some charge points that offer a mode that limits the current offered to the car so what's available from the PV system (basically the same idea as the ones that limit so they don't overload the DNO supply, but with the limit set at zero (no import)).
    Then there are more sophisticated programmable systems that can be configured to do all sorts of things - e.g. https://www.victronenergy.com/ev-charging/ev-charging-station - including excess solar diversion and making best use of time of use tariffs.
    You can even add a battery to the mix, so PV generated is available after the sun goes in and/or off peak tariff rates are in effect available all day and to the whole installation.
    Depending on your tariffs though, a much simpler solution might be viable. Some suppliers offer 15p/kWh for exported PV while only charging 10p/kWh or less for off-peak - so it could well pay just to charge the car from off-peak (using your existing timers or the car's app)  and let the PV export as it will.
  • Electric cars have a motor which I assume is 360 volt which is 230 volts time root 2 . So 400 volt DC is a good match.  How many PV panels do we need?
    The solution may be a lot more complicated than you think.  Cars that can do DC charging usually expect 400V.  Though some can also charge faster at 800V.
    Solar panels are anything but constant voltage, and the power you can draw from them depends on the insolation at that moment.  Even during the day, that power can vary by a factor of 100 between a bright sunny day and a cloudy one.
    So you need to regulate the voltage to a nice 400V.  Then implement the CCS protocols so that your charger can tell the car how much current it can draw based on how much power the solar panels are generating at that moment.  In practice, that will probably require a battery to provide some buffer to keep the thing stable.
    Most people don't bother.  They use a 230V AC solar inverter and a 230V AC EVSE to charge the car.  Not terribly efficient, but it means you have the AC grid to keep the power stable whatever the clouds decide to do.
  • Simon,
    Say I want to live off grid and be totally self sufficient.
    I can use my EV battery to run lights/TV as we cook on gas cylinder, providing there is enough power in battery to go to the shops weekly as I am now retired.
    Just need to know if 17 off 24 volt panels will do the job?
  • if 17 off 24 volt panels will do the job
     The total area of panels, the orientation,  and how far north you are, will all matter, the choices  of 24V or 60v panels and their series arrangements are less critical. There are several 'standard' panel areas.  To go totally off-grid and not run out of juice during say a week of unsuitable weather, you will need a lot of battery. Are you assuming the EV gets charged when you go to the shops in winter ?
    If you have calor gas bottles then a gas fired generator is a possible standby item, they can be very reliable going months or years between starts.
  • In the UK, in the winter, no chance.
    My solar system is pretty old and only rated 3.4kW.  Modern panels would do at least twice that.
    Today it's foggy and drizzly where I live.  My inverter tells me that the panels are generating 84W.  That's not even enough to cover the base load in the house.  My house battery is flat, as there isn't anything left over to charge it with.
    Most cars won't even try to charge below about 1.5 or 2kW.
  • In practice, going completely off-grid would be a significant project because of the highly seasonal nature of solar generation - you would find yourself with a significant surplus of electricity in the summer months, with a deficit during the winter. Home battery systems allow you to ride through periods of a few days, but the persistent lower levels of solar generation during winter would force you down the route of requiring a controllable/dispatchable back-up source of energy.
    That's likely to be some form of gen-set - diesel, natural gas or bottled propane/butane, so then you've got the purchase, running and maintenance costs of the gen-set.
    In practice, you'll likely find that the more viable route (both financially, engineering and resilience/reliability) is to get solar and a battery to maximise your self-consumption and use your grid supply as the back-up, with a suitable time of use tariff, so that during periods of lower generation you charge the battery off-peak, over-night to supplement the limited solar output. Likewise with your EV, charge from the solar during periods of higher generation, switching to charge off-peak during winter months.
    Remaining connecting to the grid also has environmental benefits, the carbon emissions from off-peak grid electricity will be lower than any stand-alone genset and remaining connection has the benefit that it is a sink for excess solar generation during summer. If you go completely off-grid, you would quite likely be curtailing your solar generation during the summer.
    This is a reasonable free tool for estimating the output from a solar installation - select your location on the map, enter details of installed capacity, mounting details. But one thing to watch, the monthly estimates show how strongly seasonal the output is, but they don't convey how variable that output is day-to-day, particularly in winter. For example, 200kWh in a winter month, so a calculated mean of ~6.6kWh per day, may have a wide distribution with clear days providing 2-3x mean, followed by a dark, dull day generating <2 kWh.
    re.jrc.ec.europa.eu/.../
