Finite Resources Could Cause a Data Centre Crunch in 2026
I see the rapid growth of AI, cloud computing and digital services creating both opportunities and challenges. One of the biggest challenges will be ensuring that we have enough energy, infrastructure and skilled professionals to support the increasing number of data centres needed across the country.
I believe the UK should take three important steps. First, invest further in renewable energy and upgrade the national grid to meet future demand. Second, expand engineering and technology apprenticeships to develop the workforce needed for this growing sector. Third, encourage data centre development across different regions of the UK rather than concentrating it in a few areas.
If these steps are taken, the UK could attract more investment, create high-quality jobs, strengthen its digital economy and position itself as a global leader in technology and innovation.
  • The old trick of selling something to the management, who hold the purse strings. Meanwhile the workers, who are supposed to use it, think it's only marginally useful.
  • They could also wrap the data centre in solar panels to generate energy that could maybe be used to power some of the electric vehicle or connect that with the heat generated and then employ some kind of steam generator to make energy.
    The possibilities are out there, we just need the UK industry and government to look towards engineers for solutions.  These solutions should then be given some kind of tax incentive as data centres become more common place on the UK landscape
  • The proposed power densities are pretty extreme https://www.datacenters.com/news/ai-cooling-systems-must-support-100-kw-racks   I'm not sure that a coating of solar panels generating a few hundred watts per panel on a good day will be enough to make a dent in it.
    Lets take that 100kW per rack figure for a moment - that's the same sort of power as the transformer that supplies 25 house on each phase in a small village. For just one rack.
    So, if we need to unhook a small village from the grid to supply each rack, how many fully populated towns have to go dark to power just one bit-barn full of them ? !  Is that a price we are prepared to pay for dancing cat videos and anodyne summaries of documents we dont want to read?
    Something is simply not going to happen at the scale, speed or power density people imagine, and I don't think the fraction of a giga-watt data centres will ever materialize.
    What you may get is a new power station, for which the base-load is assumed to be the data-centre.
     That's not to say we should not be looking at energy recovery, district heating and so on, we absolutely should, for all new power stations.
    I just  caution that there is a lot of hype and really it is quite nuanced, and we don't want a town to lose heat due to a change of profitability of some business model that may not be right.
  • Data centres are going to become more common in the UK and currently they have several issues
    Planning permission
    Site cooling
    Making the site cooling feed into district heating could turn an issue into a revenue stream for the data center.  District heating systems would also help with planning permission
    As an example this morning on Sky newse there was a piece about how a data centre was using water from the Thames to cool itself so they are currently through away the heat energy.
    www.youtube.com/watch
    It also raised the question of how mush water was being used and if this could affect water levels during the summer months when excess heat build up in the data center was at peak and during the same time that people in the local area may be facing water shortages.
    Looking to the future are we going to be discussing climate change/global warming (Personally I prefer the term climate change) being caused by data centres rather than from fossil fuels
  • Certainly running hot water to waste into a river or similar to the extent that it affects the wildlife is not the sort of thing that should really be contemplated without full consideration of better alternatives.
    At the moment of course if the data centres are anything like as thirsty or as numerous as projected, we will double our rate of fossil fuel use, or if you prefer to thing about it the other way, halve the time until it runs out, or more accurately becomes uneconomically rare to waste just for energy.
    Its not an appealing or realistic prospect, and in reality the change in national power consumption will have to be less. so there will have to be fewer bit barns built, or there will be less thirsty equipment within. What I think is  more likely is that as chip designs improve the same computing power will consume less, and the technology will only really take off in a big way, once the energy requirement per process, has fallen to a more manageable level. Until that point only the big money projects will go ahead.
  • You raise some valid concerns, particularly around energy consumption, water use and the environmental impact of future data centres.
    I agree that cooling and power demand will be major challenges. That’s why I think future data centre development needs to be linked to investment in renewable energy, grid upgrades and more efficient technologies. The example of using river water for cooling also highlights the need for careful management of local resources and consideration of alternative approaches such as heat recovery and district heating.
    On the point about energy consumption, I suspect technology will evolve in both directions. Demand for computing power will continue to increase, but advances in chip design, cooling systems and energy efficiency should help reduce the power required per unit of computing. Historically, computing has become far more efficient over time, even as overall usage has grown.
    Rather than limiting growth, I think the challenge is ensuring that data centre expansion is planned sustainably so that economic benefits, technological innovation and environmental responsibilities are balanced effectively.
    It will certainly be an interesting debate over the next decade as AI and digital infrastructure continue to expand.
  • I'm sorry to raise some concerns:
    • Incomplete or unpopulated projects as indicators
    • Even if mandated and supported by taxation Return on (ordinary capital) Investment
    • Energy Return on Energy Invested (for the Economy as a complete system)
    • Resources - especially Copper after a likely supply deficit 2030-2032, power transmission to data centres
    • Time for generator and grid build-out, which probably means diesel - diesel and JT4 have been pretty flat since 2014
    • Wider impacts of oil depletion (on all kinds of industrial products) and geopolitics
    • Politically-uncomfortable competition between ordinary consumers and these projects for limited supplies
    • Other co-location locality concerns, such as infrasound
    I think more attention needs to be paid to these
    Kind Regards
    Chris
  • but advances in chip design, cooling systems and energy efficiency should help reduce the power required per unit of computing.
    Have you seen this: https://www.bcs.org/articles-opinion-and-research/brain-inspired-chip-material-promises-low-energy-use-ai/ ?
    Yes, that’s a very interesting example. The Cambridge work on neuromorphic (brain-inspired) computing highlights exactly the sort of developments I had in mind. By combining memory and processing in the same device, these memristor-based architectures can significantly reduce the energy wasted moving data between separate components, which is one of the major contributors to AI power consumption. The researchers suggest such approaches could reduce energy use substantially compared with conventional architectures. (BCS)
    While these technologies are still emerging and not yet deployed at scale, they illustrate how advances in chip design, materials science, and computing architectures could improve AI’s energy efficiency over time. Alongside improvements in cooling systems and renewable energy integration, they may help offset some of the increasing power demands of large-scale AI workloads.
    Thanks for sharing the article.
    Best regards,
    Terry
  • One of the aspects I find particularly interesting is the potential impact on the UK. If technologies such as neuromorphic chips can be scaled successfully, they could help address concerns about the growing energy demands of AI and data centres.
    For the UK, this could support both economic growth and sustainability goals by enabling more efficient computing infrastructure, reducing pressure on the power grid, and strengthening the country’s position in AI and advanced semiconductor research. Given the UK’s strong academic research base, there may also be opportunities to attract investment and create high-skilled jobs in emerging computing technologies.
    It will be interesting to see how quickly these concepts move from the laboratory into commercial applications.
