A gravity turbine idea
Hi all,
Forgive me for such a long first post – I wanted to give some background to the situation and felt that I needed to try to explain my idea as fully as possible if I were going to ask anyone to comment on it; I do not know if there is any value in what I propose but I am at a loss as to what else to do.
In 2018 I had an idea for a new type of renewable energy turbine, and I have spent the last eight years trying to make it a reality.
At separate times I have had involvement from Professor Chris Sansom (Professor of Concentrating Solar Power (CSP) and Theme Lead, Zero Carbon at Derby University) and Professor Jo Darkwa (Professor of Energy Storage Technologies, Faculty of Engineering for the University of Nottingham). To a large degree, the issue has been the same at both institutions; namely a lack of funding. At Derby University I was fortunate that my company, Vortex Energies Ltd., was the recipient of three funded internships; but the level of funding didn’t allow for adequate modelling or sufficient practical work to be undertaken. Jo Darkwa recognises that a full feasibility study is required but has so far been unable to locate suitable funding.
It has been repeatedly suggested that I pursue investors personally; this may be an avenue for some, except that I have no experience of running a business (Vortex Energies Ltd. was only set up as part of Derby’s funding applications process). Additionally, I have suffered a couple of strokes that have left me with some physical and cognitive difficulties; even if someone were to invest in the idea, I simply couldn’t run the business side, and the technical aspects are way beyond me. I also have no connections with either engineering or physics, which would at least have offered some credibility in putting forward my idea.
To give some background to my personal situation: before my first stroke in 2016, I spent twenty years as a carer for my wife, who has ME. Prior to that (and before going to university to study archaeology) I was a Research Technician at the University of Nottingham in the Laboratory of Biophysics and Surface Analysis, Pharmaceutical Sciences.
Having spent the last eight years trying to get the idea off the ground, I promised my wife that if nothing came of the discussions with Prof Jo Darkwa, I would call it a day, considering the toll it’s taken on us both from chasing the idea for those years.
And that is where I am now. I don’t know what to do with the idea; I have no clue as to its viability and I can’t take it forward myself.
What does give me heart is that having had two professors look at the idea, they both felt it had enough merit to be worthy of further consideration. I do not know if this was a result of academic intrigue or because they felt there was a possibility of it becoming a viable business proposition? But given how limited the scope is, in academia, to pursue an ideafor its own sake these days, you might hope it would be the latter, though others will be better judges.
Feel free to contact me or ask any questions but please bear in mind that I am not an engineer or physicist, and my grasp of any technical aspect is, at best, limited.
Chris Bestwick
GRAVITY TURBINE: a system for storing and generating green electricity, as and when it is needed. A more predictable source of renewable energy, available at any time and in any weather, and with the security of mainland production of energy.
A cylindrical stator houses a rotor that gains its rotation by falling down a threaded spindle, driven by gravity. The rotor carries a payload, creating a larger mass, and thus higher potential and kinetic energy in the system.
The speed of the rotor could be governed by a regenerative braking system to maximise overall efficiency. The payload would be ejected at the bottom of the spindle to reduce the energy needed to return the rotor to the top of the spindle, where a new payload would be added. The rotor would be removed from the spindle at the bottom to be returned separately, allowing other rotors to run down the spindle unimpeded.
The payload could be anything that can quickly and easily be removed/ejected, and may be determined by local factors. Water would be an obvious choice, given its relative abundance (in the UK), its clean, non-toxic nature and possible ease of supply.
We could consider that the water supply could largely, if not entirely, be met by building a series of underground reservoirs, fed by storm water surges in rivers (given that these events are likely to become more prevalent as the climate crisis plays out), and possibly run off from towns and cities. This would have the added benefit (and possible funding sources), of reducing flooding downriver, and the water could be transported significant distances with little cost in elevation (in relation to the elevation of the turbine siting – see the aqueduct carrying water from Uzes to Nîmes, a distance of 50km with a total vertical drop of 17 meters). It would have the added benefit of not imperilling river ecosystems by taking water directly from rivers (when at their normal levels).
The rotors could be raised from the bottom of the spindle by utilising the ejected water from the rotors, which runs into a sump beneath the spindle. This then runs into a small-scale water turbine, with the generated electricity feeding into a battery-based energy storage system. Additionally, if a counterweight of containerised water is used to help raise the platform (holding the rotors), and the water is again ejected from the container at the bottom of the spindle, running into the same sump that feeds the small-scale water turbine, in tandem with the water from the rotors, it would reduce the additional required energy needed to return the rotors to the top of the spindle, if not provide it entirely.
The rotor return system could also be self-resetting, with gravity covering the hard work of raising the empty water container to the top of the spindle by allowing the rotor platform to fall to the bottom (in a controlled manner, and assuming it has a higher mass).
This could allow for a completely self-contained system of energy production, with water being the only outside requirement.
A number of rotors could operate within the same stator, their frequency determined by demand; a number of turbines could operate on a single site.
The UK has many old collieries that could provide useful sites in that they already have deep shafts as a precursor to the larger shaft needed for the turbine, whilst the prospect of employment in many of these areas would surely be welcomed. The shaft diameter could be enlarged, allowing for greater electricity generation, if the system showed adequate benefits for doing so.
A secondary shaft would be required for the rotor return system.
  • I do not know the volume of water required to flood a river basin but many river basins flood a number of times over autumn, winter and spring, and, as rainfall tends towards heavier rainfall events, floodings may become numerous. Mitigation of flooding has to happen, at a certain cost; the idea is that some of this money could be funneled towards the building of these reservoirs.
    Regarding the feasibility of building the stator; I know that CERN and the LHC use a similar structure, and they are a number of kilometres long, though I accept that the funding model of those projects is in an entirely different realm; I do not know the cost of such a structure as I have solely been concerning myself with the mechanical viability of the turbine.
    There is much that remains unknown about the idea, and most of it I simply cannot know; I have tried to turn my thoughts to potential difficulties and to work through possibilities, but my knowledge is limited in every field. But what I do know, and this is certainly true of engineering (though there will be cost parameters at play that don't hinder other projects), is that you never know what can be achieved if the question isn't asked!
