CLUTTER.
I have just been working in a two year old bungalow that has many antique brass finish wiring accessories supplied by CEF. They look attractive but the build quality is much the same as LAP. Poor.
Anyway the bungalow is fully cluttered with wiring accessories etc. on walls and ceilings.
People complain about cables or wiring accessories  that are visible, but they accept heating radiators or pipework with no complaints. Nowadays it is even trendy to have 3 metre high chrome plated radiators/towel rails in bathrooms from floor to ceiling.
Anyway this bungalow is cluttered with switches, sockets, smoke/CO alarms, front door 360 degree P.I.R. to turn on the entrance hall light etc.
Yers ago you may have had just a two gang light switch by the front door, one switch for the entrance hall light and another for the outside light. Now here there are four separate  plates side by side taking up much of the small side interior wall. One alarm plate with three switches marked LOCATE, TEST & SILENCE. A blanked off white blanking plate, and two other single accessories. All clutter, not neat at all. And all accessories are in different finishes so stick out like a sore thumb.
Then in the kitchen diner there is a high vaulted ceiling with sloping sides. The small horizontal top ceiling has two separate alarms, probably  CO and heat alarms, and two pendant drops. All very cluttered.
A double plate light switch on one wall with a metal box behind with no grommets in the 20mm holes and many unsheathed cables entering or leaving through the rough edged metal holes.
Clutter, clutter everywhere and not a clear space to see.
GGGRRRRRrrrrrrr
  • For the retro industrial look
  • Sparkingchip:
    I definitely didn’t write goat.
    Autocricket strikes again.
    On the original topic: should we not be happy with all this clutter, it is more stuff for us to instal ? Much better than the one socket in every room if you were lucky approach.
    If living in a loft warehouse I can see the point of exposed conduit but I think it has just become a trend especially in commercial buildings because it is cheaper and by saying it is the latest trendy look they can get away with a cheap solution.
    Anyway when they bring out wireless sockets will we all be out of a job?
    I stop now, the men in white are looking.
  • Sparkingchip:
    One of my customers turned a brick arch cellar into the living room of a new flat ...
    What did he do with his wine? ?
  • kfh:
    Sparkingchip:
    Wot kfh you aren't installing wireless sockets yet?
  • kfh
    It's not just trendy and/or cheaper.
    There is some science behind it too, as my mechanical colleagues keep reminding me. The thermal mass of large volumes of exposed concrete or masonry retain heat overnight in winter and are slow to warm up during the day in summer, meaning less heating/cooling is required.
