In the middle of cooking Christmas dinner with every heating element on full blast, an in-law demands a cup of tea. The kettle is plugged into the socket on the cooker switch, overloading the supply, which pops the 30A fuse in the consumer unit. Now, you do have some spare 30A fuse wire, don't you?!
Of course, there is no reason why a Commando socket should not be used.
Andrew Jewsbury:
Highly unlikely - just look at the curves for BS 3036 fuses. - a 30A fuse may well carry over 50A for a couple of hours before opening - even if the fusewire was already warm, a few minutes it takes to boil a kettle isn't going worry it (similar for the thermal element of MCBs). The old 100% of the first 10A, 30% of the remainder + 5A for a socket rule has proved it worth for probably many millions of Christmas dinners over the best part of a century - even during the times when my grandmother's generation would boil veg for 20mins at full boil with no lid.
Martin Hutson:
I believe you now need a dedicated supply for a new cooker installation with its own circuit breaker at the fuse box. There’s also a switch in the kitchen to isolate it when removing or fitting a new cooker. I don’t know why a quick safe dedicated 32amp appliance connector wasn’t developed to stop people botching up this. I was horrified to see the original state of the cabling when my kitchen was replaced.
Martin Hutson:
Would love to see a BS standard quick connector plug developed to be supplied with new cookers and The corresponding socket in the wall. The state of the cooker wiring in a lot of homes leaves a lot to be desired and think there’s a need for this. It would work a bit like a miniature version of the electric vehicle charging cable. I think with the new modern double ovens that well over 10 amps must be being drawn and overheating cabling with poor connections must be an issue . I think before Brexit it could have been a European standard but l quess this is not going to happen now.
I'm not sure if there is a long term future in a 32A plug and socket or hard wired cooker switch.
Is this the shape of things to come?
https://www.fastcompany.com/90313508/why-top-restaurants-are-getting-rid-of-stoves-and-why-you-might-too
Legh Richardson:
Out of interest, if I placed a steel bar between two induction hob hot plates what might happen?
There may also be wizard circuitry which might be able to distinguish a pan from a spoon.
