Plastic consumer units/enclosures etc
I have a job where a small former outside toilet is being converted into a hobby pottery complete with water supply and small kiln.
I propose to fit a small plastic consumer unit with the appropriate IP rating for protection against ingress of water.
This will be a home brew job with a generic enclosure and a RCD main switch and mcbs from my spares stock.
I have seen many metal enclosures rusting quietly away in detached garages/w/shops/outbuildings and thought they would be better served by using plastic.
I think there is still a case to be made for fitting plastic consumer unit enclosures in outbuildings in order to prevent deteriation caused by external influences. Moist atmosphere, unheated spaces and the like.
Any other like-minded souls out there?
Comments welcome.
  • Alan,
    Thank you for your input.
    I gather that you are situated off the mainland?
    I can tell you that much as can be discerned through direct experience of such matters, the system here does not work as you describe.
  • I have taken a call from a prospective customer this morning, the meter operative declined to replace the existing meter until the DNO had been out to replace the intake equipment,  that's been done,  so the meter has been replaced,  but both the DNO guy and the meter operative have told the customer he now needs an electrician to install a main earth and tidy things up.
    So it needs three people to tidy the intake, meter and the customers connections to them up.
    Andy Betteridge
    Crikey just logged in again and this forum seems to have been taken over by the 'girlies' or in certain circles known as the 'purple mafia' or the 'pink mafia', although the pink is generally the girlies and purple is associated with somewhat gay, shocking colour though somewhat painful to navigate for a red blooded male.?.
    Rob
  • Purple Mafia is an exciting five-piece indie rock band of teen classmates from North Yorkshire, England. Brilliant musicianship and clever, cheeky lyrics make these guys stand out as original and fun.
    THE PINK MAFIA. There's more to gay Dallas than Cedar Springs and drag queens. Behind the scenes is an upper-class network that is conservative, churchgoing, white-collar and well-connected. They have made Dallas' gay community the most successful in the nation.
    Had to look them up out of interest. Good plug.
  • Is this a colour blindness test? I've gone from light brown, to light green, to purple!
    Anyhow, back to the rant!
    How is it that it has taken so long for the RCD thing to be highlighted? Type A/Cs have been banned for some time in certain European countries.
    Another thing which came to light this week.
    Certain manufacturers are recommending that mains smoke/heat alarms be fed from their own mcb due to spurious switching events.
    Extractor fans have come on in the middle of the night, smoke/heat alarms are being 'nuisence-triggered.
    Manufacturers are claiming the root cause to be the mass uptake of LED lamps by the Public.
    What does the IET have to say about that?
    Source of info was from my independent wholesalers, who are fed up of exchanging perfectly sound goods from the likes of AICO, Manrose etc because they seem to have minds of their own!
  • R.Davies BSc(UMIST) AMIMechE CIEH:
    Rob
    Yes it has gone a little feminine - perhaps a chinz or gingham border for future developments?
    I have always thought that fires in consumer units, meters, switchgear are primarily caused by loose terminations associated with the supply intake and nearby. It would help if the people responsible for making these terminations were experienced and not part-time 'meter readers' - that's just a generalization.....
    Legh
  • On the "purple" theme - I don't like the new logo (the one the browser puts on the tab or window title) - it seems to be black (and a bit of purple) on transparent - which looks OK on when the tab is active (and the tab label has a white background) but on an inactive tab (at least on Firefox) when the background goes black it's almost invisible - making it tricky to find the IET tab again... The old one at least had a white square around the IET bit so you could see it whatever the background.
  • ? We're going a little #off-topic here...
    If anyone wants to give us their thoughts re the new branding colours etc please feel free to pop your feedback in the Online Community Support forum.
    Oh and it's not pink, it's purple... ?
  • Lisa Miles:
    Wether it be pink or purple its a b***** awful colour, so much so I now have a seperate browser for this site with the text colour changed. Also I have not bothered going to the Online Community Support forum as I am not one for surfing through loads of different pages on a single website.
  • Also you can't read the support forum pages unless you are already successfully  logged in, so not much use for anyone who cant find the buttons, and it is only slightly less of an abandoned back-water for dead topics than 'Calvin Asks'.
