ebee:
Do you really think that we actually have enough capacity for what use today?
Are you referring to generating capacity or local distribution network capacity?
I have never experienced any voltage drops caused by myself or other users overloading the local distribution network. The situation could change if electric heating or EV charging at home becomes more popular.
Are you serious about only 6 to 7A per house? My 60A guaranteed maximum was a very generous figure and based on an assumption that if a house is sucking 70A then chances are that the house next door is sucking significantly less than 60A, so across a town it somewhat balances out.
Very serious, not as a peak load for one house, that will be higher of course, but as the peak load of any large no of houses, divided by the number of houses involved, oh yes.
This is the After Diversity Max Demand (ADMD). Take a walk round and look at your nearest substation, or pole pig transformer if you are rural, note the rating (binoculars may help), then see how many sites it supplies. Or do the other sum, and add up our generating capacity, and divide by no of households. Then take a bit off the households for industry. Either way the ADMD figures are not unreasonable
The ADMD assumptions for network sizing, for various types of load are also published by many DNOs, and are based on many years of building a network that works very well, and is not over designed.para 7.1 of this UKPN doc is typical other DNOs, especially those in areas with a more rural population and a larger number of smaller substations each serving fewer properties may use slightly different assumptions when sizing transformers and the network to supply them, but not wildly so.
I repeat, there really is not a lot of slack in the curent set-up.
mapj1:
Many thanks for this document.
Brownout is an everyday word in the US as in numerous localities their local distribution networks struggle to supply enough current to meet user demands, but in the UK it seems that most people don't even know what a brownout is or even it is a real word.
The popular view is that everybody should reduce the amount of energy they use every year (climate change?!) but is the REAL problem the UK faces not the overall increase in kWh of electrical energy but potential current peaks following a transition from gas heating and petrol / diesel vehicles to electric heating and EV charging?
If the answer is yes then could it even result in a scenario where it's almost impossible for a house to suck more than 10A due to current throttling but the kWh allowance over a year is so large that the electricity is effectively free?
perspicacious:
Whilst "standing charges" for energy have been decried in some of the previous posts, no one appears to object to the phoneline rental nor the TV package service from above that could be £60/month.....................
The Scottish Socialist Party (then run by Tommy Sheridan) had a policy of abolishing line rental charges for landline phones, but did not mention anything about mobile phone tariffs. This was at the time when an increasing number of people were replacing their landlines either with mobiles on tariffs that provided a large unmetered phone time allowance for a monthly standing charge, or for low users mobiles on a pay as you go tariff with no standing charges, as it was becoming cheaper (and more convenient) than a landline.
It was joked that the Scottish Socialist Party was the 0141 party.
Sparkingchip:
So how many EV charging points will each home have?
