mapj1:
1967, the BBC split the Light Programme into a pop music and entertainment network. The Light Programme became BBC Radio 1 and BBC Radio 2 long wave. The BBC Third Programme became BBC Radio 3, Home Service was renamed BBC Radio 4.
In 1978 radio 4 moved to a longwave channel on 198khz, and radio 2 moved back to medium wave.
Does Radio 4 continue on longwave for strategic reasons?
1. The shipping forecast - moved from Radio 2 in 1978.
2. For Royal Navy submarines to detect if the UK (probably) still exists and hasn't been blasted off the face of the earth!
mapj1:
. . . I do know there have been attempts to raise funding for a re-start of a modern LORAN like system (circa 100KHz ), as a back up for critical navigation at sea, as GPS has proved to be rather too vulnerable to jamming for comfort . . .
AncientMariner:
. . . back in 1976 I visited the Decca Navigator Green Slave at Neston, about 7 miles north of where we live.
Sometime in the late 1990s, just before the shut-down, I peered through the wire at the Decca Navigator Red Slave (North British Chain) located at Clanrolla, Northern Ireland.
You won't find Clanrolla on Google Maps (I think it might be a townland) but if you find Castor Bay Road and follow it north of of the M1 towards the lough, then you are in the right sort of area. I can't actually remember exactly where it was myself!
Unfortunatley I don't have any photographs of the station. It was dismantled and removed sometime in the early 2000s and as far as I am aware, nothing remains on site.
As for the eLORAN trials, the general story from beginning to end seems to be summarised in the following Notices to Mariners from the Comissioners of Irish Lights. The trials actually go back a lot further than I initally thought!
https://www.irishlights.ie/safety-navigation/notices-to-mariners/2007-04-eloran-transmissions.aspx
https://www.irishlights.ie/safety-navigation/notices-to-mariners/2007-06-eloran-transmissions.aspx
https://www.irishlights.ie/safety-navigation/notices-to-mariners/2008-02-eloran-transmissions.aspx
https://www.irishlights.ie/safety-navigation/notices-to-mariners/2012-13-eloran.aspx
https://www.irishlights.ie/safety-navigation/notices-to-mariners/2015-11-eloran-trial-discontinued.aspx
