Would you re-use 'used' RCBO's / other item's too??
Hi, just wondering whether it's prudent to re-use 'used' RCBO's, RCD's, fuses etc like; MCB's, switches, DSO's, SWA's, CCU's and the rest?
What do you think and... what electrical items have you re-used, if any?
Regards... Tom
    Tomgunn:
    All the best...
    regards... Tom
    and you, mush - hope the medico's can sort you out for a few more decades
    Good luck
    OMS
  • Well thank you OMS... very kind of you... lets wait and see, a?
    Best of health, and luck, to everyone!
    Cheers!
  • I would consider it very poor practise to re-use secondhand equipment for a paying customer.
    The main exception would be in the case of obsolete or no longer readily available parts, under which circumstances re-use is justified if the customer is aware of this and approves it.
    Just recently I installed several old light switches obtained from fleabay, the reason being that new switches suitable for 250 volts DC are not available.
    I might make the odd exception for virtually new components that have seen very limited use, but not regularly.
    I am more relaxed about use of serviceable but used equipment for free/very cheap jobs done for friends, relatives, and charities. Or of course in my own home.
    No issue using ‘seconds’ if needed..
    on Friday  I fitted a load of old square edge MK stuff I obtained of eBay as the flat owner wanted MK to match the existing MK. I only charged for exactly what the materials cost me and explained they were used seconds but I checked over and all seemed in good working order.
    what I really liked was the 3 old style switch spurs had the old wrap around terminals for the load side for the stranded cable.
    But as above old stock / seconds are generally used for cheap temporary jobs or mates rates jobs
    Agreed Dusty.
