mapj1:
Generally people are less conductive than salt water ,and more conductive than fresh.
If you are the high resistance element, you do not want to be in series with a body of conducting water - swimming as it were in between the capacitor plates and finding most of the volts dropped across you .
davezawadi:
It is very unusual for "ships" to connect to shore supplies, partly because loads can be quite large, and secondly because it ends up being very dangerous. Smaller boats are a bit different, and often plastic, so may be considered a bit safer. In the UK we insist on TT supplies which should be OK, but one still finds the odd narrow boat plugged into a random mains supply. We cannot win them all.
Alasdair Anderson:
The fatal current doesn't circulate in the middle of the swimming pool. You need to be at the edge, preferably grabbing on to a metal hand rail or similar.
Interestingly the Americans have also managed to kill people swimming in rivers/marinas/lakes due to connecting their boats to a shore supply and getting circulating currents (https://www.boatus.com/seaworthy/magazine/2013/july/electric-shock-drowning-explained.asp), mainly children, and even avoiding the need to grab an earthed rail if the voltage gradient in the water is sufficient. It may also be enough in a swimming pool. Note that the lack of RCDs in the supply systems (a requirement in the UK for supplies to small vessels as far as I am aware) is a major reason for such faults being undetected until it is too late.
Alasdair
weirdbeard:
Zoomup:
Very dreadful.
https://www.youtube.com/watch?v=IusjgjINVn0
Z.Hi zoomup, not sure if you are aware, but as an aidey des memories you have previously posted about this 2014 incident back in 2014
https://www2.theiet.org/forums/forum/messageview.cfm?catid=205&threadid=59630
Zoomup:
weirdbeard:
Zoomup:
Very dreadful.
Hello Weird,
You expect me to remember that far back?
