gkenyon:
(b) The reason it leads to a clunky design is that the plug has a fuse, which gets warm in use, and the heat needs to be dealt with (end of physics lesson).
AJJewsbury:
Are you going to change the symbol "I" for current as well - after all that's another French invention (by Monsieur André-Marie Ampère) - perhaps to the more obvious (to Anglo Saxons) "C"? (Although you might then have to come up with something different for all those correction factors...)
Why not put it in the socket (outlet)?
And a BS1362 fuse can be very reluctant to blow when overloaded.
(c) We can't do away with the fuse whilst we still retain ring final circuits.
Simon Barker:
Alasdair Anderson:
Simon Barker:
And a BS1362 fuse can be very reluctant to blow when overloaded.Any fuse will be very reluctant to blow when overloaded - fuses are not overload protection, they are short circuit protection. From a 13A fuse protection you should be able to draw 20A for a significant duration (BS 1362 possibly indefinitely but certainly >3 hours). Generally overload protection is to protect the equipment, short circuit protection is to protect the electrical installation - somewhat simplified and I am sure you can think of many caveats and exceptions but in principle, that sums it up.
Alasdair
Harry Macdonald:
"Why not put it in the socket (outlet)?" Because the normal reason for a fuse to blow is a fault in the appliance so you take the faulty appliance together with the blown fuse to someone who can fix it.
