Inverters?
Happy Easter to all! ?
My friend's escaped Ewell, due to where we are today, and staying on his narrow boat he's owned for decades and is spending most of his time, apart from the beer, doing lot's of repairs.
Now, what's missing from his ship is... a washing machine. The thing is, the power supply, to that area of narrow boat ships', is somewhat low so, I suggested about an 'inverter'. He said that some of those ships have installed 'inverters' BUT, they have to have lot's of heavy duty batteries.
Can an inverter be run off of the mains'?  I guess that that may be a stupid question as the inverters' that I have run off of my car battery supplying 240v so, I KNOW how amazing you lot are and the wealth, (grovel, grovel), of information is unrivaled!
So... he want's a 3K washing machine... can an inverter be worked, without lot's of batteries, to run this?
Thanks...
regards too, Tom
  • I doubt that a modern white-goods heater is more than two-and-a-bit kW (~10 A). That seems a very standard Europe-wide limit point. Interested to hear of exceptions such as a 3 kW heater. The suggestions of avoiding electric heating are of course sensible. Modern washing machine don't need to do much water heating when they work at 30 degC and use so little water compared to old ones. Dishwashers of course do need some more heating, and it can't all be done by supplying hot water. Brochures stating energy use could be helpful: normally the kWh of a 'standard' program can be found, though without distinction of heat and motor load.
    My main point to make is that inverters are not equal, and nor are loads, even if they are similar sorts of device.
    A really good inverter gives a fair approximation of a sinusoidal output voltage, regulates its magnitude to within a few volts of the rating over much of the rated load range, supplies up to its stated ratings for continuous and peak as long as provided with a strong enough input source. It also has reasonable safety with regard to the risks of its chassis, battery inputs and output-socket earth-terminal getting dangerous voltages between them; it might have some RCD-like function to detect leakage, or run its output as a floating system.  That sort of inverter comes at a cost: I believe it's some hundreds of pounds for something into the >2 kW category. I've only played with such things belonging to other people.  Someone doing a nice job of a boat or caravan should get such a device. Those that I've seen for sale from respectable places in Europe (not mail order from far away) have all so far been good in the above ways, except possibly the waveform if they're somewhat cheaper ones declared as not being "true sine".
    Loads can also be very varied in what surges they take on start-up, and what voltage-dip from an inverter they tolerate during such surges.  If the inverter has a bad voltage waveform (cheaper types), typical modern IT-stuff like chargers and computers will run fine from all I've seen, but might reputedly have a shorter life with the higher stress on diodes and capacitors.  I'm interested to know more from Graham about sensitivity of different types of motor drive.  That comment made me wonder whether any manufacturer will 'approve' an inverter unless it's basically emulating a normal low-impedance, largely sinusoidal mains supply: I doubt the market of off-grid users is yet big enough to make it worth sounding permissive beyond "at your own risk"?  Anyway: even if the load is a "washing machine", they won't all be equal in their interaction with a given inverter.
    As a little information about the other side of the spectrum, I'll mention a little about the inverters I've used, just for some sockets in my car. I don't care about the "power quality" or the happiness of the things plugged in, such as the ancient toaster by my feet in the winter, or passengers' chargers, or my laptop charger.  I just want as much power as I can get, at next to no cost. So mine is one of those highly dodgy eBay-mediated imports from the far east (Hong Kong I believe, in this case). I've imported a fair bit of eBay-mediated electrical equipment of various sorts, mainly through interest at seeing what it contains. It's seldom disappointing: i.e. there's usually something horrific, even if the basic function is actually very good. In the case of inverters (of which I've had several) I can say that the cheap ones fail on every point mentioned above. The output voltage is what's deceptively called "modified sine-wave" [see e.g. here], which basically means a square wave with another shorter one piggy-backing it. That's ok for many things, but may stress capacitors and diodes a bit more. It can make some loads noisy (audibly). The ratings are not true: my latest, from 2017, claimed 2000 W continuous and 4000 W peak.  It doesn't quite get to 1500 W for a second, even when applied in small added doses of resistive load with the input voltage held in the specified range. The output voltage drops to <200 V when coming up to its maximum output (of 1500 W: this is 1500 W *rated*, i.e. it's actually a good deal less as the voltage is below the intended). And I have to do some bonding of the chassis, output earth terminal and an input battery lead in order to be confident that a fault in the straight-onto-chassis semiconductors wouldn't cause a dangerous voltage. I mount an RCD on the side to protect the output before it emerges. The output isn't isolated, and can trip the RCD for faults on either pole. I would not want to run it in its supplied state. The supplied output socket was a universal type with big gaping holes and no connection of the earth terminal.  However, on the positive side this latest one cost £30 and free shipping, and after my modifications has served for 2½ years sitting on top of the battery in the engine compartment, partly shrouded in a freezer bag apart from the ends where the air goes through.
  • A calor gas powered genset may well be cheaper and easier to organise (or a small diesel one) What is the boats prime mover ? I have seen some impressive stacking of alternators on an engine to get lots of aux power.
    Not quite  this image  this but same idea
    And low wattage helps
    caravan washing machine - typically 150 to 250 watts or so depends on size
  • There is a downside to filling a dishwasher or washing machine, because the wash is faster soiled items don’t soak for so long and things don’t come out as clean as they do from a cold fill machine.
    Andy B.
  • Hi all, crikey!
    WOW! Love the posts'!
    Now, how to get shot down by everyone. It was great, reading your replies. Very good suggestions too. Maybe get my friend to buy a generator / definitely forward, the above, to him... I, naively, thought that you could, maybe, get a transformer, (this must show you my ignorance on this matter), that would feed some type of inverter and do away with the need for multiple batteries BUT, as I can see there would be far more into this than trying to do away with batteries..
    I do know that the supply, to the area, of his narrow boat, is very poor and all of the others are in the same, (sorry for the 'pun', haha), boat!
    Many thanks for all the great replies, once again... just goes to show you what an amazing site this is!
    regards... Tom
  • If you get him to get a generator tom, there are considerable downsides. Noise is the first, Honda used to make a 300W one which was incredibly quiet but once you get to a few kW they tend to be noisy, which is a problem if other boats are present. Also it is best to avoid petrol on boats as the vapour tends to sink to the bilge and is then very dangerous and usually unnoticed If the boat has a diesel engine then an additional alternator is the way to go, charging a nice big battery as it is hidden, has a wet exhaust and probably acoustically managed too. Again I advise 24V or more, it gets the battery current more under control, an it is unwise to discharge lead acids at more than C/5 (5 hour rate) for longest life. Your car battery tends to last quite a short period because of engine starting, a fork truck battery several thousand complete cycles at c/5 or less, although they are deep discharge types which helps. You will notice that stop-start (supposedly lower emission) car batteries are much more expensive because of the horrible life they suffer! Electric traction batteries are what you really want, and weight matters little in a reasonable size narrow boat.
  • davezawadi:
    Hello Dave..
    Good points, I'll pass all of this on to him... lot's of details, from all, that I wouldn't have thought about, well done everyone!
    regards... Tom
