Chris Pearson:
In practical terms, if you need to put furniture against the other walls, the space under the windows may be all that is available.
What you shouldn't do is cover the radiators with floor-length curtains. Unfortunately that is exactly what Mrs P likes and then she complains about the cold. ??
Posted by broadgage on Mar 4, 2020 12:01 pm
For optimum comfort and minimising draughts and condensation, then yes radiators should be placed under windows.
For minimum fuel use and therefore minimum running costs, then radiators should be on inner walls and away from windows. Placement under a window implies an outside wall, with heat losses through the wall and through the window.
If heat sources are on inner walls, then any losses are only into other rooms rather than to the outside.
Sparkingchip:
Apart from the possible waste of heat, placing electric heaters under windows has to be potentially dangerous as they may be covered with curtains if the users of the heaters don’t have the good sense not to cover them, as I have seen happen.
