RichardCS2:
AJJewsbury:
But at least the loop impedance is kept low with a MEN system - even if it might drift a bit above local earth potential. With a fully TT system if the consumer's electrode is just in dry dust you might loose all ADS as well as having leakage currents raise the voltage on the earthing system.Of course if the ground really is that dry that you can't get a good connection to it even with a foundation earth or buried tape then it also implies that the risk of shock to earth is low. If you can't manage to earth a great big electrode then a couple of bare feet won't be very well earthed either.
mapj1:
yes - but then when it rains, and the shock risk is higher again, the ADS also works.
Yes, OZ expect new earth rods to have the tops insulated, and actually we are also encouraged to put the tops of our earth rods in pit boxes, which has a similar effect in that it reduces the accessible voltage during fault. (I know no-one does)
The isolated shearing station with Kylie Mingue (you should be so lucky...), may have even more of a problem as it may well have a single phase or split phase LV, fed by single wire earth return HV, so the HV earth is carrying the HV current for normal loads too.
An intro to SWER for the non-believers. Very effective, but scary.
and a demonstration of the concept at 120v by a young man who wears goggles, when I'd be happier if he wore gloves on youtube here
Zoomup:
Just run a twin and earth cable from the house.
RichardCS2:
Zoomup:
Well there's always this: https://ludens.cl/paradise/turbine/turbine.html DIY 2 kV transmission line with homebuilt transformers starts about 2/3 of the way down the page. 2 pole 1.5 mm^2, 10 kVA, 600 metres back to the house. Voltage drop works out as about 3.5%.
mapj1:
Sparkingchip:
mapj1:
That’s a very scary extension lead.
Andy
