Wolfie100:
Thanks all for replies so far. I like the idea of a hard slab like material above the cable, do you think my BC employed inspector will? I have seen that you can still buy cable tiles, just quite expensive. I do believe 300mm to be within spade/fork depth but agree that a piece of robust slab with warning tape above should reduce risk to almost insignificant. The option of going around the obstruction to avoid areas that may be dug in the future is extremely difficult if not impossible.
Wolfie100:
. . . I like the idea of a hard slab like material above the cable, do you think my BC employed inspector will? I have seen that you can still buy cable tiles, just quite expensive. I do believe 300mm to be within spade/fork depth but agree that a piece of robust slab with warning tape above should reduce risk to almost insignificant. . .
Don’t be tempted with a metal pipe - it needs to be fairly obvious what is in it. Metal may well get mistaken for an old water pipe and someone just cut through it with a Stihl Saw. At least with plastic, if it’s contents are unknown it can be carefully opened to see what is inside.
Alan Capon:
It is worth mentioning that there is a standard for plastic ducting to determine what is in it. The most often used colours are:
Black - LV Electricity
Yellow - Gas
Blue - Water
Purple - Motorway Communications
Grey - Telecommunications
Green - CCTV, Cable TV, Fibre Optics
Orange - Street Lighting, Traffic Signals
