My concern is that the earthing of all of these lights relies upon exported TNCS from the CU (s). This is via a 1.5mm core plus armour in the SWA. Is this sufficient?. The lights are fairly old and I believe designed to be earthed ( I do need to check this). Each one is bolted down to concrete in the ground.
