420 Watt Hedge Trimmer.
The owner of the 420 Watt hedge trimmer decided to redesign the 0.75mm2 two core flex by cutting through it. This caused a dead short. His house is supplied by a TN-C-S supply. It has a consumer unit in the house with a B16 M.C.B. dedicated to supply his garage. The house consumer unit is a split load type with 30mA R.C.D.s. The hedge trimmer had a 13 amp plug fuse fitted. It was supplied via an extension lead fused at 5 Amps.
In the garage, where the hedge trimmer was plugged in,  there is a two way garage unit with a B16 M.C.B. for the sockets and a 30 mA R.C.D.
When the hedge trimmer flex was cut through which protective device(s) tripped off or ruptured?
  • I threaded by hedge trimmer flex through a bit of old hosepipe so it is now too fat to get into the teeth of a hedge trimmer. (that was after I cut the flex once).
  • Mr. Zoomup, I am not trying to make a case to prove you wrong, but your approved answer is only half right. With a long thin extension lead plus connected hedge trimmer lead, the resistance of the leads can act for a split second as a heating element thus giving a bit of delay before a fuse or circuit breaker will operate. The short is to fast for fuses or circuit breakers to react. A 13amp fuse fitted in the plug-top (usually) can flout established conventions, therefore nothing will trip or blow. Obviously my answer is based on a limited number of cases of same I had to rectify but unexpected results quite true as I have written and precisely true to myself.
    Regards, keep safe
    jcm.
  • jcm:
    My Dear Sir,
                            your observations are most welcome and are very illuminating. The facts as set out were confirmed by me in a real life situation so are accurate in their description of the event.
    Thank you for taking the time to contact me.
    Yours sincerely,
    Head of Hedge Trimmer Repair Dept.
