Alcomax:
At first I thought this was DIYr seeking advice
for there own home.
Obviously not. If you were to adopt your economical method, it would be near nigh impossible to justify it " officially". If you showed this for an "assessment" for a scheme, perhaps, I would like a front row seat and a bag of popcorn please.
So the house is just 60amp single phase and seems to be a lot going on.
You have 3 phase elsewhere.
Can you not ditch the 60 amp house supply and run new supply direct from 3 phase to suit the needs of the house?
I am not an electric professional but this is my father's house I am seeking advise for. We will be hiring an NICEIC electric company to do our work but I am helping explore options to formalise our ask.
The distribution box for the 3 phase supply is across a rear garden, carport and a driveway. There is a huge TPO protected tree in between and we would need to rip out a lot of the existing structures to run a direct supply.
The other option is to disconnect the power supply for outhouse, extend the SWA using a resin joint and move the consumer unit to the room in Building B we are talking about now then link all existing circuits to the new DB.
Massive PITA and the outhouse is only supplied by a 10mm2 5 core SWA :/
A while ago there was I think a wiring matters article about ring circuits that demonstrated the load from a typical kitchen appliances over some hours and how the 20A cable wasn't overloaded for long periods.
