mapj1:
Or for light duty situations the all-insulated lamp post You could do worse than call them to see what they offer for your situation Tel +44 (0)1623 511 111 I have no connection with the company other than our maintenance folk ordered a replacement post for a funny situation from them once.
Quote:
”GRP does not conduct electricity, it is an insulator. As our columns are constructed entirely from GRP, they are a class 2 product. Being Class 2, our columns require no electrical earthing connection, therefore affording savings on installation. There is no risk of electrocution from touching the column, making it an ideal solution for low / medium voltage areas.”
so so how do you install a cable without armour buried in a duct?
mapj1:
Hmm, interesting, one for the potentially useful products library, thanks!
Sparkingchip:..<snip>
If you are are a DNO, earthed concentric wiring, but if you are to BS7671 then you can still use an armoured cable - the armour can remain earthed at the origin and linked to be continuous all the way along, and will do its duty and blow the supply fuse when a digger finds it, but until that moment, the armour does not have any connection to the terra-firma around it.
PS I'm not a street light expert, I'm transplanting knowledge of things done near radio transmitters, where earthing and and what is at what voltage also matter. Things like aircraft warning lights on transmitter towers are something else, and involve isolation transformers in strange places.
