Cable Sheathing Material "LSZH"
Hi,
I hope someone can assist.
I am interested in studying the materials used to sheath "LSZH" / "LSF" cables, particularly ones such as twin and earth.  Can anyone confirm what kinds of compounds are typically used to sheath these cables?  Specifically LSF/LSZH ones, so not PVC.  I had assumed XLPE but a number of manufacturers seem to state "LSZH" sheath etc alongside XLPE insulation, so I am lead to understand the sheath is not XLPE... or am I overthinking it?  I have tried to asking a manufacturer but I have not had a clear answer.
Looking forward to some answers.
Thanks,
    Just looking for lightweight conduit but needs to be LSZH type for fire protection requirements.
    Would you be able to help?.
    Ian
  • JIMMY2RIVERS:
    Ian
  • OMS:
    Sure  - reliance on a standard that has identified and repeatable test criteria has to be better than some vague description of performance like "LSF"
    As for gel filled cable, then I tend to not run it more than say 1 - 2m into a dedicated Building Entry Facility (BEF) before terminating it and converting to a more sensible indoor grade cable spec. Make the BEF as fire sterile as possible, and wrap it up in 60minute protection - not usually a problem if you consider your comms to be important to you
    That's explained something that has puzzled me for years, inexplicable joints just before entry when I always thought another few meters would have seen the cable to its final destination without jointing 200 pairs up a ladder.
    I was after a catalogue reference number for a LSZH Type of Conduit if anyone knows of any it would be greatly welcomed.(ie RS Catalogue number so we can look at buying some in).
  • Like this ? Plastic LS 0H from CEF
    Hi Mike,
    Yeah do they do a open slot or sprial-wrap type of conduit in that spec.
  • JIMMY2RIVERS:
    Hi Mike,
