Thomas Ward:
Its a 32amp mcb thats tripping and a 40 amp rcbo which is in the main board , I was working on a lighting circuit but this has somehow caused the ring main 32 amp mcb which is in the flats cu to start tripping and also the 40 amp rcbo which is in the main board . Its a flat with its own cu which is fed from a main board .
Hi Thomas Ward, it would be a great help if you could post any pictures?
