mapj1:
well if we are that bothered, and want something that can be driven in by the electric driver then pan head/ button head allen bolts in M6/M8 M10 all exist, and can be pulled up very tight very fast and with a lot less slip slide and risk of cut hands than a flat blade driver. Should have change from the price of a pint for a bag of 50 in steel rising to about 5p each for stainless example
Do about avoid anything less than about M5 in this head style, the really small ones like M3 tend to have shallow engagement and can round out too easily - if you must then torx head.
My first impression was that the OP was describing button head screws, but are we not thinking about what used to be wood screws?
Problem is that Spax (and others) largely sell countersunk screws and they are what is available in my local builders' merchant. It vexes me to use countersunk screws in back boxes, but they do seem to work.
As for trunking (or anything similar) the traditional approach would have been round-headed (Japanned) steel screws. The nearest now does seem to be pan headed, so in answer to the OP, that is what should be used.
As for the driver, my preference (ignoring cost) would be Torx, hex (Allen, not external hex) posi, slot.
