The term "strokes of lightning" has been used in a literary manner, as of brush stroke in the sky
davezawadi (David Stone):
Obviously my dictionary is older than the English language. However, I am not going to argue further, in a PC world it is probably safe to say that my hitting someone is simply a "stroke of the hand" in court or that swimming strokes are GBH. I will however stand up for exact and clear communication, which these examples are not!
Moving on, it is not clear what the SPDs are supposed to prevent, if it is not large electrical discharges (which is what the test waveform is meant to represent) just what is it? It seems to be being suggested that all mains connected electronic power supply failures are caused by "mains transients" of some description, with the general form of lightning, which is simply not the case. I have always had and operated large quantities of Electronics, and none of it has ever been damaged by any kind of mains transient, whether from a generator or "mains" supplies. Obviously there has been the odd failure, but I could not say that transients had been the problem, usually heat, age, or normal component failure. Much of the equipment has various transient suppression features, VDRs, snubber networks etc. but these are part of robust designs. This seems to me to be a solution looking for a problem again, a problem that I don't and never have had. The only damage I can think of was telephone line related, in that this was a couple of miles long and lightning tended to damage my modem, and in one case the phone too. Also, the line filters were remarkably unreliable, but the components in there were probably rated for 50V when the ringing voltage was greater than this, and the DC was pretty much 50V. Bad design to the fore. Again I see problems elsewhere being cured at the consumers' expense.
443 PROTECTION AGAINST TRANSIENT OVERVOLTAGES OF ATMOSPHERIC ORIGIN OR DUE TO SWITCHING
wallywombat:
How about this for simplified SPD criteria:
An SPD must be installed if any of the following apply:
(i) risk of injury or to life;
(ii) risk of financial / data loss;
(iii) if the owner and designer etc have reached a consensus that damage would be intolerable, unless a risk assessment shows transients unlikely.
Why don't you submit a comment suggesting that ...
