broadgage:
Even a 3 phase 100 amp supply might be marginal with a couple of 22Kw vehicle chargers. ...
I am pretty sure that the DNO will not contract to supply 69 kVA. I am not quite sure how ADMD is applied to a single property, but I got 30 kVA.
More than one 22 kW charger seems silly. That's about 80 - 100 "mph" so unless somebody is spending several hours per day behind the wheel, that sort of power is just not needed. Even with a 100 mile round-trip commute (and no charging at work), each car would only be charging for an hour a day. One will do with perhaps a second 7 kW charger so two vehicles may be charged simultaneously.
I am sure that diversity will take care of things, but let's suppose that it doesn't. If the occupier is out for 8 hours per day and asleep for another 8, the only substantial use will be for 8 hours. Let's say that an average of 50 A per phase is consumed. That is 50 x 3 x 8 x 0.23 = 276 kWh per day. Let's assume a tariff of £0.15 per kWh. That comes to £41.40 per day or £15k per year!!!
Calm down folks! ?
Ventilation of this property of 1 air change per hour will need far more than Andy has allowed
AJJewsbury:
Building technology has moved along quite substantially in the last 15 years or so - new builds are now incorporating levels of insulation that a generation ago were thought to be physically almost impossible and increasing fuel prices and likeley future fuel scarcity are making high levels of insulation more and more attractive, especially in the self-build sector (what will you run your gas boiler on once North Sea gas runs out?).
Coal gas! ?
It's a bit windy here today, so the windows are rattling. That certainly wouldn't happen in a new build. When I first heard about pressure-testing new houses, I thought that somebody was having a giraffe, but no, 'tis true. That is despite the presence of open chimneys, ventilation bricks and, of course opening windows. ?
Sparkingchip:
That £15k per annum includes the electricity used to power a couple of cars instead of petrol or diesel, which could easily explain away at least half of the total if not more.
Electric cars still have “fuel” costs.
Andy Betteridge
Take this Renault Zoe on EBay as an example, ball park figures appear to put the lifetime running costs at double those of a similar car with a petrol engine.
| 2014 RENAULT ZOE Dynamique Intens 5dr Auto - 10500miles, 87bhp Without battery, you need to rent a battery from Renault. Prices start at £49 a month and is dependent on annual mileage |
