mapj1:
Chris, the wobbly choc block has been done, by John Ward.
Try about 5 to 6 mins into this video for an idea of how well it works with a light load for that sort of fault, or about 23 mins into this one, for a higher fault current.. I found it underwhelming in the extreme in both cases.
Mike, thank you. That is exactly what I was thinking of except that perhaps he could have tried a larger load (though I take his point about most of them being small ones in homes) or perhaps he could have "tuned" the choc-block.
I found it got a bit boring!
The presenter in this video claims that in the US, AFDDs have reduced numbers of domestic fires by nearly 20% - good enough reason to install them, is it not?
Farmboy:
There were 3,862 fires due to faulty appliances and leads in 2019/20 (Government fire statistics). It isn't clear by any means how many were started by an arc, let alone a detectable one, but let's assume for the moment that all of them were.
The average area of damage was 16.5 m² i.e. the size of a fairly ordinary sitting room. I haven't found official statistics, but Plumis who make sprinkler systems say the average cost is £25k, which seems reasonable. For comparison, new build costs are around £2,000/m².
There is no indication whether fires caused by faulty appliances and leads are bigger or smaller than average. So 3,862 fires @ £25k = just under £100M per year.
There are 24.4 million dwellings in England (Government dwelling stock statistics) so the cost near as makes no difference is £4 per dwelling.
If an average AFDD lasts 20 years, then a whole CU-full needs to cost less than £80.
I conclude that at the moment, AFDDs are not cost-effective.
Now then, would nobody care to discuss the cost-benefit ratio of fire alarm systems? ?
