wallywombat:
Does anyone know whether there's a simple relationship between current and power emitted by an arc? I don't know what the effective resistance of a plasma's arc is, but perhaps at below about 2.5A not enough heat can be generated at the site to ignite anything?
I have been thinking about that. I have also been thinking about the spark which ignites a cigarette lighter. Surely it must depend upon the presence (or absence) of any fuel and the temperature attained. (Fire tringle - fuel, oxygen, heat.) That's why I come back to the PVC choc-block. If it melts, then ADS should take over. If it doesn't melt, how can it get hot enough to ignite?
"Fire in Electricity Meter and wiring. Large cupboard within hallway. Owners attempted to extinguish with Dry Powder Extinguisher."
"damage confined to scorching behind electrical socket. extinguished on arrival."
"Tumble dryer destroyed. Extinguished on arrival. Motor burnt out"
wallywombat:
There isn't a simple relationship sadly. As the arc current rises, the density of conductive ions rises - if you like there is more ionised plasma (charged smashed up bits of atom) floating about, so the arc resistance falls - giving a negative dynamic resistance, meaning the voltage dropped falls as the current rises, which is not stable. To strike an arc without contact you need a very close approach, and a high enough voltage to jump the gap initially. Then you need enough current to be available without the voltage dropping too much to allow a decent volume of plasma to build up. With no current limit the ball of hot ionised gas grows without limit, but in reality there is always a current limit at some point, even if it is the substation fuse !
In the case of the 2.5 amp load there is an open arc with approx 100 ohms in series, so as the arc resistance falls its share of the voltage falls, and when the voltage drops low enough the arc will go out. Then the voltage rises and there is a re-strike usually this repeats and leads to the periodic buzz in time with the peaks of the mains waveform.
regards Mike
ebee:
Do we put them in the same bin as voltage conditioners in domestc properties?Snake oil!
That's harsh! ?
They do actually detect potentially dangerous arcs. The real question is do such arcs exist in practice? The consensus seems to be no. Take the much-vaunted burnt out shower switch. If a terminal is not properly secured, is the over-heating due to arcing or due to only a couple of strands carrying the full current?
