Working through lockdown.
Halfway through this second lockdown are you finding that customers are expecting business as usual?
  • RB1981:
    But ultimately life has risks, and I'm not convinced that COVID is particularly much greater a risk than many other things. But I don't really want to get into a debate about the merits and demerits of the restrictions - which in my view are totalitarian and unjustifiable.
    Covid may not present much of a risk to you, but it does to older age groups, which is why everybody should be aiming to minimize transmission. Clearly  economic activity had to increase, but I am bound to wonder whether the avoidance of social contact could have prevented the second wave.
  • The highest risk group I can come into contact with are those living in rented homes, particularly Homes in Multiple Occupation.
    The lowest risk group are the elderly people living alone that are having bathrooms replaced to enable them to continue living in their own homes.
    I really do not want to be transferring anything from the first group to the second.
  • wallywombat:
    RB1981:
    Indeed the recent Damask-19 research in Denmark found no particular evidence for the efficacy of masks.
    That's not the case. For one thing, that study only looked at whether masks protected the wearer, while the main reason for wearing masks is to prevent the wearer infecting other people. And the sample size was too small, which meant that the results weren't statistically significant (which means that you don't know with any sort of statistical certainty whether the results are accurate, and not, as people often assume, that there wasn't any significant difference between mask an non-mask wearers).
    As WW says, it was looking at infection rates amongst the wearers and not at rates of infection in the community.
    It is incorrect to say that the sample size was too small - it had been calculated to be able to detect a halving of infection rate from 2% (as it was at the time of the study) to 1%. In the event, around 2% were infected in both groups with -0.3% difference between the groups i.e. a higher rate in the mask-wearers; and there is a 95% chance that the difference was from -1.2% to 0.4%. So the accuracy of the trial is not in doubt. There is a 2.5% chance that the masks reduced the infection rate from 2% to 1.6% or less.
    The question of a statistically significant difference as against a significant real world difference may be illustrated quite easily. Let us suppose that a morning's operating list consists of 4 patients whose operations take 45 minutes each on average. A study finds that glueing the skin together at the end saves an average of 5 minutes with a 95% confidence interval of 10 seconds i.e. there is a 2.5% chance that less than 4 m 50 s were saved and a 2.5% chance that more than 5 m 10 s were saved. The result is undoubtedly statistically significant; but what are we going to do with the 20 minutes saved? It isn't enough time to do another operation so the difference is not significant in real world terms. (Save that you can have a longer tea break. ? )
    ETA: the Danish paper is here
  • Interesting.
    More generally there are a lot of articles based on a a poor grasp of the stats of C19 at the moment.
    I'm inclined to agree on the mask wearing thing - certainly in the UK, absent any specific mask quality requirement, we cannot really say it does much, and in terms of behaviour it may make things worse, as now it is 1metre plus or 2 metres without, so people feel more (unwisely) confident to come closer together generally.
    At my place of work we are supposed to wear a mask moving around the place, but do not need to wear it while working at a location once we have got there.
    I suspect the saving grace for  us is actually not that at all, but the fact the folk do not come in if they are feeling unwell, and given only a few hundred are on site rattling about in a building designed for rather more means that both the chance of anyone in the building having it is low, and the chances of them passing it on are also low.
    For folk working with lots of sources or lots of possible victims, for example in schools or old folks homes I suggest the risk of becoming a carrier, if not a victim, is less negligible, and worth trying to reduce where practical.
    Mike..
  • The longer this epidemic goes on, the more confused I become. There have been so many changes and new laws that it is difficult to keep track of them.
    It is permissible for a tradesperson to work in somebody's dwelling, but is it permissible to stay away from home in order to work? (Venue and place of work are too far apart to travel daily.)
