It could be that the company has calculated that the additional investment would not be adequately recouped in the remaining FIT term.
I had my PV installed near the beginning of the scheme. At that time the economics were not so obvious. The costs were more than double that of today, and it was not simple to estimate the amount that would be generated, there was little history of domestic installations to go on.
The installations are rated at a peak output, but there was limited information on what the practical generated output would be; you could either rely on the salesman(!), or calculate it from the efficiency of the panels and sunshine data for your location. In practice my 3.8 kWp does not generate more than 2.6 kW on a good summers day, and rarely at that. Most of the time it is much less. At that time I estimated that the FIT would pay back the capital outlay in just over 10 years, in practice it was 8 years 9 months. The installation is now just over 10 years installed.
Only in the last 6 months have I been able to monitor the energy exported to the grid. I had always thought it was more than the 50% they pay for, in practice if the last 6 months is typical 50% is surprisingly accurate.
The energy company email me every 3 months asking for a generator meter reading.
David
Edited to tidy layout
mapj1:
Well, according to this website to install a replacement inverter is a simple DIY task.
I do wonder if quiet a few get started and then get stuck when something is not as expected.
M.
Do you realise that is the website of a guy who was at one time a frequent contributor to this forum?
Sparkingchip:
An internet search throws up hits such as this:
Most Utility Companies will assume a 50% export and do not measure the actual amount fed back into the grid.
http://www.energygrants.co.uk/solar_power/solar-pv-feed-in-tariff-calculator.html
Which seems a lot more practical than relying on people in their eighties and nineties to submit regular meter readings.
Yes they assume 50% export - but that's 50% of the total generation - so you still need a PV meter and it needs to be read & readings submitted. The policy just saves the need for a 3rd meter (or for the supplier's meter to register exports separately).
Sparkingchip:......
No, but I wish him well. I just imagine that there are more call-backs to self fits than the description implies. A straight swap will be easy - but I wonder how many older rigs really are a straight swap, and how many have the wrong sort of DC wiring, earthing issues or are missing an RCD for the new inverter etc.
I'm also reminded of an issue I got involved in a while ago with tingles on roof due to solar panels that was down to things not being earthed in the way you may expect.
