Simon Barker:AJJewsbury:Meanwhile, this morning's exercise in safe isolation.
Presumably not the connection to a PV inverter either?
- Andy.Any standards compliant inverter will switch itself off if it loses connection with the mains.
Indeed - but it takes time - supposedly 5s for older ones but seems it can take longer if the conditions are just right (wrong). I recall someone inspecting my installation throwing off the main switch and having time to say "er, why's that light still on?" and me to reply "I'll be the PV inverter - it should shut down soon" before it actually went dead.
Sparkingchip:
Adding a fused connection unit to an existing socket circuit.
So I plugged the socket tester in and could hear it buzzing, I knocked off the first MCB and it stayed on, so I turned it back on and turned the second MCB off and it was still buzzing. So then I turned them both off and the socket tester stopped buzzing, so then I tried alternating between the two MCBs and decided it was time to alter the wiring in the consumer unit, as the ring circuit had a MCB both ends.
It really is not a good idea to believe what it says on the consumer unit labels.
Chris Pearson:
Well, somebody must have had a very odd idea of a ring final. Were the neutrals and CPCs together in the neutral and earth bars, or had two terminals been used in each case.
The "electrician" seems to have known that each leg of a ring can carry 20 A, so for my money, confused rather than clumsy.
Ah! You spotted the 20 amp MCBs!
It’s all good fun.
