Commercial EICR strategy?
Hi,
I've been tasked to do some EICR's on some commercial Car Showrooms. There's lots of old DB's, little or no circuit details and the previous EICR's stated that nothing could be tested due to not wanting circuits switched off. Personally I don't think it's worth even reporting if you aren't testing anything?
I wondered if anyone had a strategy for dealing with these situations. I'm not looking for anymore work so I'd rather not fail anything unless I absolutely have to. The customer wants as little interruption to the supply as possible.
A possible strategy:
Visual check
Identify circuits where possible
Take Zs readings where possible
Check db's for signs of thermal damage
Zsdb and ipf's
Check bonding
Check tightness of terminals in db's and sampled accessories
Report on what I've seen and tested with limitations on everything else.
It is going to be impossible to identify cpc's and neutrals associated with each circuit. IR testing would have to be very limited.
Below is a picture of what I am up against. There's a mix of old and new db's with many BS3871 MCB's.
Any advice guy's?
  • perspicacious:
    chap who after leaving Southern Elec went off to do bank jobs
    Did he ever get caught Legh?
    BAD
    Of course not. In after dark and Out before the sun rose.
    Left the place spick and span, no nails, screws, dust and wiring detritus on the carpets  Skirting boards replaced and newly painted left to dry in place. New sockets and switches ready to use but alas no wife.
    After several years of making good money his wife ran off to enjoy evenings and weekends with somebody else.
    Legh
  • Bod
    Looks like 3 meters to me?
    I've yet to learn how to enlarge the posted image John, but I thought the far left one was a single-phase check meter but it now looks as if its a separate incoming single-phase supply cut out under it.......
    Did you like the sheared brass bolt image I sent you for your files?!
    BED
    tattyinengland:
    If you have to only do live testing (Which does happen in some environments) a very helpful addition to what you have described above is a mA Earth leak detection on the tails - this will give a good indication of possible IR deficiencies - especially any N-E faults (Lots of Amps earth leakage). Further Investigations may be then be the outcome to the EICR.
    Afternoon tatty,
    First time I've tried this but I've clamped the tails on various DB's.
    On the Main DB that feeds 5 other DB's around the unit including the Comms room I'm getting around 50mA which peaks at around 75mA every so often.
    There's an Aircon DB which I get a pretty constant 40mA at.
    There's a showroom lighting and general power DB which I get 20mA at.
    How do those figures look? Would I be looking for readings of Amps rather than mA to indicate possible issues?
    Cheers
    wallywombat:
    You could ask them why they've requested an EICR and/or what they want out of it. The answer to that would influence the testing strategy and scope. To comply with their insurance company's requirements? Or they want an idea of whether they need a major rewire/upgrade? Or random things keep tripping and taking out lots of other stuff and its getting annoying? Or they're just H&S conscious?
    Hi Wally, it's for insurance purposes. Anyone know what insurance companies are looking for?
    Would a 30 mA RCD stay in at these values?
    BOD
    Yes, to pass the risk onto you if you issue a satisfactory EICR, hence the need for PI insurance and your willingness to stand up in court to explain why you didn't record as unsatisfactory the item that you're up in court for!
    As above, risk and reward.
    BOD
    John Peckham:
    Bod
    Hi John,
    The main service head, 3 ph, feeds one meter (right hand lower) and the majority of the db's via henleys.
    There's a PV import meter (above main meter). PV feeds into henley blocks.
    Looks like the supply is looped to the left, single phase, to feed a economy 7 which feeds a redundant storage heater board and an Air Con board.
  • AJ Spark:
    Fundamentally they're looking for a satisfactory report, so that they have less risk of paying out for the the building burning down or someone being electrocuted.
    If that's the case, then the car showroom people will probably be very happy to agree in advance with you that many things can't be tested (e.g. no power downs due to customers on site / cars being serviced etc). The idea being that this will cause you to issue a satisfactory report - a report which is very clear on what the agreed limitations on inspection were.
    Hi BOD, looks like I'd have issues on the Aircon db but the rest would be OK if those 5 db's shared the leakage? I've not used this method before so I'm not sure what to expect in terms of leakage. What's your take on it? Cheers
