davezawadi (David Stone):
Interesting point Andy, but rather out of date in application as we have better methods than choc block now. If I use proper crimps, I do not need to inspect, therefore don't need an enclosure. I would be perfectly happy to join a large cable, so why not a small one using the same method? Resin filled joints basically use this method and are not inspectable, being crimped (or even screwed) joins in a cable surrounded with suitable insulation. There is no "enclosure" as such, only a mould for the resin, which is a flimsy "enclosure" I suppose, but not openable. The days of the big cast-iron box and pitch have long gone. Perhaps this is another bit that should be changed? I see no reason why suitable tape or adhesive heat-shrink should not be used, both waterproof and excellently insulated, what more could I want?
I guess the other characteristic is fire-proofness (is that a word?) - any kind of joint (even one that doesn't need subsequent inspection) is a weakness and is for more likely to be subject to overheating and perhaps fire than the original conductor.
Both of the materials I have suggested are much more fireproof than PVC Andy, please be sensible. Crimp connections made properly are not subject to overheating. This idea you have is simply daft!
Why the comparison with PVC? Most electrical enclosures aren't PVC and I suspect those that are are sufficiently modified to be able to pass a glow-wire test at least. In poured resin joints I'd imagine that the hardened resin forms a suitable enclosure rather than the mould. I think it's confusing to suggest that meeting the requirements for non-accessibility is the same as meeting the requirements for enclosure - 526.5 and 526.2 are quite distinct requirements.
There is no mention of the fire rating of the enclosure even if it is made of standard building materials, say wood.
By PVC I was really referring to the cables, particularly sheaths, which are inflammable if PVC.
