mapj1:
The detail is not your problem,
but pass the electrics in the flat ( if they are OK) but a short letter needs to be forwarded to the freeholder/ commonhold association chairman or whoever. Perhaps the flat owner can take it to the next meeting.
Agreed,
My concern was passing an installation that has C1 and C2 defects within its sole isolation.
I have dedicated Inspection boxes on the EICR for such Items.
A quick (and dirty) fix would be to add a Red head just prior to the meter, that way there would be the obvious demarkation for supply.
It fails anyway on the switch fuse for the supply to the flat, holes in it and arc shields removed etc, probably asbestos back in the day.
Cheers
mapj1:
I'd say don't bother, pre meter is Building networks, and adding an unexpected red head to the BN is not really help to make it any safer- it could just as easily have been sealed Henley blocks combining the meter tails, and you'd not open those. Mind you in that case the metering company pulls the DNO fuses to the whole block off to change a meter - I know as I have a flat in just such a building (DNO fuses, horrible mess of 35mm tails and sealed blocks to meters, and then after each meter a 63A switch fuse and a T and E lines out to each flat.) Demarcation is then the meter
You could add a switch fuse maybe, but it will probably be the same fuse value as the box of danger and it too has the drawback of making the dangerous part no safer further if pre meter needs abstraction proofing, and you probably strictly need BNO permission to do it (if they even know).
Someone else will be doing any remedial works tbh, just thinking out loud.
These days you would not get a meter installed without the red head in place after the MSDB / before meter to start with, not sure how long it has been in the EDS though.
Last few jobs UKPN / Meter operators seem to be quoting ’the book’ at every point.
