Sparkingchip:
Having core drill a 4” hole through the wall and having installed the fan the bathroom fitter asked why I don’t use a “box” like the other electricians.
https://www.toolstation.com/tumble-dryer-condensing-kit/p65417
Snake oil!
I don't know how much water might be in a full tumble drier, but I assume that it could be of the order of hundreds of ml. Does it fit in the box?
How does the water condense? Is the box cooled?
AFAIK, in a condensing tumble drier, the outgoing warm moist air passes through a heat exchanger so that the incoming air is heated somewhat. At the same time, the cool incoming air causes the water vapour to condense after which it is either pumped into a reservoir, or expelled down a drain. The benefit is twofold: first, less electricity is used; second, the room does not overheat.
This kit strikes me as being about as useless as those freestanding air conditioners which allegedly remove the heat from the air by turning it into water.
ETA: the "best" modern tumble driers use heat pumps to heat the incoming air. I gather that they take ages and ages to dry the clothes.
I have a very good condensing tumble drier, so the water is returned to me in a tank. It is usually about 2 litres per load from a 1200 RPM spin washing machine, which feels pretty dry to the touch. A quick wash and 800 spin and it is more like 3 litres, certainly a lot more than freely vented driers suggest.
I have a friend who has a new “fancy” flat with a wash and dry machine that room vents the air. He has a serious problem with black mould and condensation and is buying a dehumidifier to solve the problem.
Venting to the roofspace is probably a bad idea!
The heat pump is not more than the tumble drier with an internal dehumidifier, eh Chris?
The reply box has changed again!!!
These fueled appliances without inlet air vents are not permitted by the BR, and probably will not cause poisoning, but will not work properly if there is no airflow through the fuel and up the chimney. Burning fuel without enough air does not cause too much CO generation as the temperature rapidly falls, this is the regulation method on most enclosed stoves, they just burn more slowly. Making Carbon monoxide is not quite as simple as may be imagined, certainly, my stove makes none (as tested by me) except a tiny amount in the flue when well-raigned back.
I have just had a thought, are the vents missing in order to get a good airtightness test, and a higher class of energy efficiency? All this shows a distinct lack of joined-up thinking by both regulations and policy, as usual!
davezawadi (David Stone):
Not quite. These driers still condense, but instead of heating the air using resistive elements, they do so with a heat pump. The consequence (as I understand it from reviews) is that the drying cycle takes longer, presumably because the drying air is not as hot.
