Recommended wiring topology for multiple lamps on one switch?
As having an array of mains downlighters or spotlights in a ceiling is now fashionable, (rather than a single central luminaire), this begs the question of how to optimally and correctly wire them all up to the light switch.
In the case where one light switch operates multiple lights (as powered by from the domestic lighting circuit), there are several possible ways to wire from the switch to each of the lamps.
[It is taken as obvious that each lamp needs to be wired in parallel, with connections to the mains neutral and the switched-live wires.]
The (twin-and-earth) cable routing from the switch to all the lights and could be one of:
1) Daisy-chain   (the cable goes from the switch to one lamp, and then on to the next lamp, until all lamps are connected)
2) Ring    (like the daisy-chain wiring, but the final connection then links back to the switch to create a "ring main")
3) Star   (separate cables go from the switch to each lamp)
4) Tree   (i.e. a balanced spanning-tree, where the cable goes from the switch to two lamps, and each of them connect to two lamps, branching until all lamps are connected)
Each topology has different implications regarding the current distribution, and its associated heating losses in each segment of cable.
For example, a Daisy-chain topology has the highest current loading in the cable segment closest to the switch, but it uses the least cable; whereas the star topology has equal current loading in all its cable segments, but it uses the most cable.
Do the IET regulations recommend a particular wiring topology for particular scenarios, and what does everyone use in practice?
Thank you
  • what is a "circuit watt" as opposed to a "watt"
    It's the power that flows in the supplying circuit, rather than just the lamp. E.g. an 18W fluorescent fitting might draw current equivalent to maybe 25W once you take account of control gear losses etc.
  • Thanks AJJ that makes sense. Although I would myself take such things into account, in fact I`d never run a circuit that even approaches 2/3 of capacity for lighting circuits anyway.
    Mapj yes that makes sense. As ever guidance notes (approved docs) are just someones way of applying a reg anyway.
    It`s amazing what becomes folklore, NICEIC (or more precisely some of their approved electricians) are among the worst offenders.
  • If there’s twelve lights in a room I don’t worry that there must be two switches with six on each, if splitting them 8/4 or something similar gives a nice pattern and allows the lighting level to be adjusted sensibly then I’ll go with that. But I would not generally put all twelve lights on the same switch, at least try and keep to the spirit of the thing to give a practical solution to reducing electricity consumption.
    Andy
    Andy
    Andy
  • Clearly there are merits in all topologies but it's the pragmatic considerations that will normally make the decision for you.
    But do 'future you' a favour (and anyone else who comes to this installation later) and leave an 'as installed' sketch of the chosen layout.
