From a house ring main can an external rcd socket be used as a fused spur to a small consumer unit in a garage less than 10m away using 2.5 buried protected cable? (2 LED strip lights and 4 double sockets in the garage)
					You are quite right it is in theory an extension lead and it would fit a plug as i tried a connection test when i laid the cable in Entelle plastic ducting. I just want as much earthing protection as possible hence the consumer unit in the garage and an rcd in the external sockets.
RCD sockets and RCD fused connection units to BS 7288 are not currently recognized by BS 7671 for isolation or additional protection without upstream RCD protection and isolation.
Steve
Why don't you do a proper job and run a steel wire armour cable or steel conduit to your garage supplied from a separate way on your consumer unit?
JP
There are quite few caveats…
Steve Mc:
A CU in the garage won't make a jot of difference to that.
Is the circuit RCD protected?
Are there any services (gas, water, oil) in the garage?
					John, i totally agree and in normal circumstances would but the main consumer unit is at low level in a kitchen with laminate flooring and this will EVENTUALLY come up and a new consumer unit installed however currently i cant get a lead from it to the back of the house.
I think if you are of the opinion that putting it on a plugtop therefore fused to 13A or less rather than say an FCU fused in a similar manner makes it become non notifiable with regards to Part P etc I`,m not sure that distinction would stand up if you are taken to task about it. Opinions might differ on that one
					That's why I am asking advice ebee.. and I thank you all. !! I will want it all certifying eventually and with as little mods as poss. the external RCD double socket will be fed from the ring main via a FCU i'm just not sure whether to just plug the Garage connection or to hard wire it to the external sockets?
Steve Mc:
Initially leave sufficient length of cable at the R.C.D. outside socket neatly coiled so that when the new consumer unit is installed it can be connected to that. I personally would use a steel wire armoured cable for the underground garden route, but your cable may well be protected from gardening damage if it runs under concrete or paving slabs for example. The underground cable route is best R.C.D. protected if it is not armoured cable, for safety reasons.
