Shower with no RCD or supplementary bonding
I have been round to a relatives flat and seen he has an old Wylex board with MCBs. His bathroom has no supplementary bonding from what I can see and no RCD protection for his electric shower. how potentially dangerous is this? I know the circuits are fairly short and can see main bonding in place Can only really think if the R2 values are low enough touch voltages should end up being kept low?
  • Thank you Mike so if you was to code this what would you code it if carrying out an EICR?
  • well if it is to be rented out it would have to be fixed,  as rented rules now require this, but if not then it is nor so serious.
    Note I do not do domestic electrics for work ,so  my engineering judgement is based on 1st principles, not napit codebreakers or whatever,  and maybe 3 or 2 depending what else is going on.
  • No it’s not rented out just an old flat with an old wylex board ?
